[mapserver-dev] RFC 62: Support Additional WFS GetFeature Output
Formats
Yewondwossen Assefa
yassefa at dmsolutions.ca
Sun Oct 10 15:22:05 EDT 2010
>> - out of curiosity, will you introduce a zip library like minzip in
>> this work? I was looking into this for kmz output.
> GDAL already had io infrastructure for minizip "unzip", so I added
> minizip "zip" in GDAL and GDAL exports a simple API to use it.
> That's what I'm using in mapogroutput.c, but the downside is that
> it is only available if using GDAL 1.8 or newer.
> One benefit of using minizip from GDAL is that it can easily
> assemble the zip in memory using the /vsimem/ stuff instead of
> having to write it to disk. Of course that could be accomplished
> with appropriate io hooks for minizip "zip" if it was incorporated
> directly in mapserver too.
ok thanks. I will look into mapogroutput.c when working on the kml driver.
>> * re. gml_include_items: are you thinking also of using
>> gml_exclude_items and aliases? I am not sure I can think of other
>> mechanisms to get the list of attributes.
>> * re strong tying: would the gml_[item_name]_type be enough to do a
>> valid output (if It is defined), or were you thinking have having the
>> types in MapServer at read time?
> I'll have to look into the gml_[item]_type.
> OK, having looked it over a bit, it does seem like it should be
> sufficient for setting field types, though obviously it would be
> preferable to have a way of getting this information from the
> original driver itself.
> Perhaps in some circumstances we should allow the feature source
> implementations to set this metadata if it isn't already set?
> What downsides do you see to that? Perhaps "gml_types=auto"
> would request the source driver to supply the types if it can?
I believe automatic detection of types would be good. I think the
gml_[item]_type was introduced only because the detection was not
provided by the source drivers. I do not see any downside allowing the
drivers to provide the type using gml_types=auto (or even if it is the
default behavior without the user having to set it)
best regards,
Assefa Yewondwossen
Software Analyst
Email: yassefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax: (613) 565-0925
