[mapserver-dev] Checking the use of a qix file
Lime, Steve D (DNR) Steve.Lime at state.mn.us
Thu Sep 2 11:29:33 EDT 2010
I guess I'd draw the map (e.g. indexed data) and overlay it with the shapetreevis output. If the features are in the map (and the index was used, so you'd have to zoom in a bit) but there's no quadrant data then it's a shapetreevis issue. How do you know quadrants are missing? I mean, how are you testing in the first place...
Steve
-----Original Message-----
From: mapserver-dev-bounces at lists.osgeo.org [mailto:mapserver-dev-bounces at lists.osgeo.org] On Behalf Of Jeff McKenna
Sent: Thursday, September 02, 2010 6:46 AM
To: 'MapServer Dev Mailing List'
Subject: [mapserver-dev] Checking the use of a qix file
Devs,
We need to check that a qix file's quadrants are in fact being used by
MapServer (shptreevis for some reason generates a shapefile that is
missing a few quadrants).  It could be a problem with shptreevis, or a
problem with the qix file.
Does anyone have any ideas how to debug that?
-jeff
mapserver-dev mailing list
mapserver-dev at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapserver-dev
