[mapserver-dev] Checking the use of a qix file
Thu Sep 2 12:16:48 EDT 2010
Lime, Steve D (DNR) wrote:
> I guess I'd draw the map (e.g. indexed data) and overlay it with the
> shapetreevis output. If the features are in the map (and the index was used,
> so you'd have to zoom in a bit) but there's no quadrant data then it's a
> shapetreevis issue. How do you know quadrants are missing? I mean, how are
> you testing in the first place...
Folks,
For reference this turned out to be just a bug with shptreevis not producing
full output if there were more nodes in the .qix than there were shapes
being indexed.  I am committing a fix, but there is no impact on .qix
generation or use in mapserver.
Best regards,
