[mapserver-dev] Proposal to add built-in OpenLayers map viewer
Dan Little
danlittle at yahoo.com
Mon Sep 27 16:17:39 EDT 2010
I sorta like the idea of "mode=browse" and then "template=[template]"
Then have a "$prefix/share" directory that contains the "openlayers.html"
template. So, "mapserv?..stuff..&mode=browse&template=openlayers", would then
read form the share directory and regurgitate openlayers.html with any parsing
freebies we could pore into it.
----- Original Message ----
> From: "Lime, Steve D (DNR)" <Steve.Lime at state.mn.us>
> To: Daniel Morissette <dmorissette at mapgears.com>; MapServer Dev List
><mapserver-dev at lists.osgeo.org>
> Sent: Mon, September 27, 2010 1:45:37 PM
> Subject: RE: [mapserver-dev] Proposal to add built-in OpenLayers map viewer
> Makes sense and would not prohibit other built in templates down the line. So
> I'd be cool with mode=openlayers or even just mode=browse returning a basic
> OL template if nothing else is defined.
> Steve
> -----Original Message-----
> From: mapserver-dev-bounces at lists.osgeo.org
>[mailto:mapserver-dev-bounces at lists.osgeo.org] On Behalf Of Daniel Morissette
> Sent: Monday, September 27, 2010 1:11 PM
> To: MapServer Dev List
> Subject: Re: [mapserver-dev] Proposal to add built-in OpenLayers map viewer
> The need I'm trying to address is the ability for mapfile developers to
> quickly test a mapfile just by typing a simple URL in their web browser.
> While I can appreciate that admin tools and generic templates for all
> sorts of viewers and frameworks would be nice to have, that is out of
> scope for what I am currently proposing.
> What I propose is to add a simple function to mapserv.c (just a few
> lines, really) that will spit out a few lines of HTML/JavaScript to
> instantiate a very simple OpenLayers based viewer for a given mapfile
> in response to a mapserv CGI request with mode=openlayers or a WMS
> GetMap request with format=application/openlayers. I do not envision the
> use of external or configurable templates for this since that would
> imply dependencies on external files an I would ideally like something
> really simple aimed at mapfile developers that works out of the box with
> just the standalone mapserv executable and a regular mapfile without any
> special configuration.
> Does my explanation make sense? Is this not considered useful enough by
> itself to justify adding to the mapserv CGI? If there are no objections
> to this little addition then I will write a RFC for it.
> Daniel
> Lime, Steve D (DNR) wrote:
> > So where are we at? I do like the idea. The technical solution, IMHO,
> > will probably point to how this might work operationally. For example,
> > if the plan were to simply embed a HTML/OL template in code then a
> > mode=openlayers would make sense. However, if the template were stored
> > externally and a basic one shipped with MapServer then I'd opt for
> > mode=browse&template=openlayers. The advantage of the external templates
> > is extensibility and users could edit the one(s) provided or add their
> > own. They could also disable the functionality altogether by removing
> > all templates. The downside is setting up access and then security. If
> > external templates used the templating code and magic strings that would
> > mitigate many issues...
> > Steve
> > *From:* mapserver-dev-bounces at lists.osgeo.org
> > [mailto:mapserver-dev-bounces at lists.osgeo.org] *On Behalf Of *Tamas
>Szekeres
> > *Sent:* Friday, September 24, 2010 4:46 PM
> > *To:* Daniel Morissette
> > *Cc:* MapServer Dev List
> > *Subject:* Re: [mapserver-dev] Proposal to add built-in OpenLayers map
> > viewer
> > Daniel,
> > Adding a viewer with zoom and pan capabilities is a good idea which is
> > better then having a single image in some cases. I foresee a reasonable
> > Web administration interface to mapserver could also be established by
> > such additions which would be a requirement too.
> > However embedding code from a separate project seems to be a hassle,
> > though the technical solution hasn't yet been mentioned in the ticket.
> > I would be in favour of doing either:
> > 1. Create a simple (mapserver specific) .js to provide the required
> > functionality (which could be extended later with further options)
> > 2. Provide a (pluggable) interface for use by the potential viewers in
> > mapserver, and create a separate support package for at least one (like
> > openlayers for instance) and include the external code to this package.
> > (Just to put my 2 cents in)
> > Best regards,
> > Tamas
> > 2010/9/24 Daniel Morissette <dmorissette at mapgears.com
> > <mailto:dmorissette at mapgears.com>>
> > This was discussed at the code sprint in Barcelona, and I just created a
> > ticket for it. We'd like to add this to 6.0... but I am realizing just
> > now that maybe I should start with a RFC...
> > Anyway, here is what I wrote in the ticket, please feel free to comment,
> > keeping in mind this has to remain __simple__:
> > http://trac.osgeo.org/mapserver/ticket/3549
> > Every once in a while we get requests for a simple way to test a
> > mapfile. One way to handle this could be to do as GeoServer does and
> > provide a built-in OpenLayers based map viewer. In the GeoServer case,
> > this viewer is returned when one issues a WMS GetMap request with
> > format=application/openlayers in it.
> > I propose that we provide a similar functionality in MapServer, which
> > would be triggered in one of two ways:
> > 1- Using mapserv?map=/path/to/my.map&'''mode=openlayers''' ... in this
> > case the viewer would be initialized based on the mapfile defaults, and
> > some of the traditional mapserv CGI params may also work (such as map
> > size, layer selection, etc.)
> > 2- Using '''format=application/openlayers''' in a WMS GetMap request as
> > GeoServer does. Note that in this case the rest of the GetMap parameters
> > would be used to configure the map to view (BBOX, WIDTH, HEIGHT, LAYERS,
> > etc.)
> > Both cases would call the same function internally to produce a simple
> > OpenLayeres viewer with one singletile layer for the whole map with the
> > selected layers.
> > Daniel Morissette
> > http://www.mapgears.com/
> > mapserver-dev mailing list
> > mapserver-dev at lists.osgeo.org <mailto:mapserver-dev at lists.osgeo.org>
> > http://lists.osgeo.org/mailman/listinfo/mapserver-dev
> Daniel Morissette
