[mapserver-dev] v6 beta 4 Cairo PDF and raster
Brent Fraser
bfraser at geoanalytic.com
Wed Apr 13 12:08:36 EDT 2011
Never mind; I was confused (I had set STATUS OFF and forgot to change
it back). The raster_simple_opacity.map works fine.
Best Regards,
Brent Fraser
On 4/13/2011 9:53 AM, thomas bonfort wrote:
> On Wed, Apr 13, 2011 at 17:49, Brent Fraser<bfraser at geoanalytic.com> wrote:
>> no opacity: PDF with rgba.tif (good)
>> opacity 50: PDF with yellow background (not good)#
> and abolutely no raster overlayed?
> with the current trunk?
> what version of cairo?
>> Best Regards,
>> Brent Fraser
>> On 4/13/2011 9:39 AM, thomas bonfort wrote:
>>> and what do you get with msautotest/renderers/raster_simple_opacity.map ?
>>> On Wed, Apr 13, 2011 at 17:34, Brent Fraser<bfraser at geoanalytic.com>
>>> wrote:
>>>> Thomas,
>>>> I'm using the test map file and data:
>>>> MAP
>>>> NAME TEST
>>>> STATUS ON
>>>> SIZE 400 300
>>>> EXTENT 0.5 0.5 399.5 299.5
>>>> IMAGECOLOR 255 255 255
>>>> SHAPEPATH "../gdal"
>>>> IMAGETYPE CAIRO_PDF
>>>> OUTPUTFORMAT
>>>> NAME 'CAIRO_PDF'
>>>> DRIVER CAIRO/PDF
>>>> EXTENSION "pdf"
>>>> END
>>>> LAYER
>>>> NAME grey
>>>> TYPE raster
>>>> STATUS default
>>>> # OPACITY 50
>>>> DATA data/grey.tif
>>>> END
>>>> END # of map file
>>>> When OPACITY is used, the raster data is not included in the PDF.
>>>> Commenting out OPACITY results in a PDF with a raster.
>>>> Best Regards,
>>>> Brent Fraser
>>>> On 4/13/2011 9:24 AM, thomas bonfort wrote:
>>>>> Brent,
>>>>> I've just committed [1] two tests for raster data, and pdf supports
>>>>> opacity. We'll need more info...
>>>>> ps: don't be confused by the .png extensions, the .pdf.png file is
>>>>> really
>>>>> a pdf
>>>>> thomas
>>>>> [1] http://trac.osgeo.org/mapserver/changeset/11555
>>>>> On Wed, Apr 13, 2011 at 16:49, Brent Fraser<bfraser at geoanalytic.com>
>>>>> wrote:
>>>>>> Thanks to all involved in fixing the problem
>>>>>> (http://trac.osgeo.org/mapserver/ticket/3799). Shp2img no longer
>>>>>> crashes,
>>>>>> but the OPACITY doesn't seem to work. Can someone confirm that?
>>>>>> Thanks!
>>>>>> Best Regards,
>>>>>> Brent Fraser
>>>>>> On 4/1/2011 9:46 PM, Brent Fraser wrote:
>>>>>>> shp2img crashes when rendering a tif into a pdf using:
>>>>>>> MAP
>>>>>>> NAME 'topo'
>>>>>>> # Map image size
>>>>>>> SIZE 800 800
>>>>>>> UNITS meters
>>>>>>> EXTENT 285000 5435000 291000 5440000
>>>>>>> PROJECTION
>>>>>>> 'proj=utm'
>>>>>>> 'zone=12'
>>>>>>> 'ellps=WGS84'
>>>>>>> 'datum=WGS84'
>>>>>>> 'units=m'
>>>>>>> 'no_defs'
>>>>>>> END
>>>>>>> # Background color for the map canvas -- change as desired
>>>>>>> IMAGETYPE CAIRO_PDF
>>>>>>> OUTPUTFORMAT
>>>>>>> NAME 'CAIRO_PDF'
>>>>>>> DRIVER CAIRO/PDF
>>>>>>> EXTENSION "pdf"
>>>>>>> END
>>>>>>> LAYER
>>>>>>> NAME '082h04'
>>>>>>> TYPE RASTER
>>>>>>> DATA 'C:\Inetpub\wwwroot\Topo\data\raster\SHADING\08H04.tif'
>>>>>>> STATUS DEFAULT
>>>>>>> OPACITY 50
>>>>>>> PROJECTION
>>>>>>> 'proj=longlat'
>>>>>>> 'ellps=GRS80'
>>>>>>> 'datum=NAD83'
>>>>>>> 'no_defs'
>>>>>>> END
>>>>>>> END
>>>>>>> END
>>>>>>> I'll file a ticket...
>>>>>> _______________________________________________
>>>>>> mapserver-dev mailing list
>>>>>> mapserver-dev at lists.osgeo.org
>>>>>> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
