[mapserver-dev] Precision about geotransform
thomas bonfort
thomas.bonfort at gmail.com
Thu Apr 21 13:33:09 EDT 2011
Mohamed,
I'm guessing that as the underlying data drivers only accept
rectangular extents oriented northwards, they have to return more data
if there is a rotation implied. And mapserver also has to filter the
extra features out at some point, even if they do not fall on the
final map image. This could explain the overhead.
thomas
2011/4/21 Mohamed Saâd HESSANE <saad.hessane at gmail.com>:
> I don't think so. If it was, juste when a cos or a sin vanish.
> My first thought was that mapserver have to calculate more pixels in a
> rotated map than a normale map. But when i read the source code i found that
> it's the projection which rotate, not the map. So why this discimination?
> The same projection
> 2011/4/21 Stephen Woodbridge <woodbri at swoodbridge.com>
>> On 4/21/2011 10:32 AM, Mohamed Saād HESSANE wrote:
>>> Hy list,
>>> I have a question. I'm doing a benchmarking test of a rotated map, and i
>>> get the result in the attached file.
>>> My question is why it take more time to draw a map rotated at 45° than a
>>> map rotated at 90° or 183° ???
>>> Thank you !
>> I'm only guessing here but could it be that the math required to compute
>> cos and sin is more costly in cpu cycles at those angles.
>> Regardless, this is an interesting question and I love the graphic, nice
>> job on that.
>> -Steve W
>> mapserver-dev mailing list
>> mapserver-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
