[mapserver-dev] Possible to use PostGIS as a
TILEINDEX to shapefiles?
Stephen Woodbridge
woodbri at swoodbridge.com
Wed Apr 27 23:38:28 EDT 2011
Brent,
It would be good to bug this as it is a good idea and something that
could potentially come out in a point release if it is not overly
disruptive code-wise because it should be transparent to most operations
(i'm guess as I have not dug into the code, and it might impact mapscript).
-Steve W
On 4/27/2011 11:02 PM, Daniel Morissette wrote:
> Unfortunately too late for 6.0 as you had already figured out. However
> you could use OGR connections for your PostGIS tileindex and to read
> your shapefiles with the current version.
> Daniel
> On 11-04-27 08:42 PM, Brent Fraser wrote:
>> I've used a PostGIS layer as a TILEINDEX to raster files, but it doesn't
>> seem to work for pointing to shapefiles.
>> And looking at mapshape.c at line 1901 it checks:
>> tlp = (GET_LAYER(layer->map, tSHP->tilelayerindex));
>> if(tlp->connectiontype != MS_SHAPEFILE) {
>> msSetError(MS_SDEERR, "Tileindex layer must be a shapefile.",
>> "msTiledSHPOpenFile()");
>> return(MS_FAILURE);
>> mapraster.c has some logic around line 410 that seems more generic.
>> I wonder if it would be possible to fix this for 6.0, or is it too late
>> now that rc1 is out?
