[mapserver-dev] KML OUTPUTFORMAT
Guillaume Sueur no-reply at neogeo-online.net
Thu Dec 1 10:18:32 EST 2011
I'm testing MapServer KML OutputFormat and am experiencing strange
issues...
First is a question : why is KML OUTPUT needs WMS requests when SHAPEZIP
uses WFS ? Using WMS for getting vector feature is a bit disturbing.
Second is a consequence of the previous. If I copy a WMS request from my
logs and just change format=png to format=kml, it works great. If I
paste this URL in Google Earth, it is still OK (but static). If I want
to have auto-refresh of my features on camera stops, I then paste with
URL without BBOX, which is then added by GoogleEarth. BUt the result is
then unpredictable (coords like 5,45 are received in 280,430 or
whatever). I discovered (after a while...) that it goes mad when BBOX
proportions don't fit the height/width frame, which is impossible to
update with GoogleEarth.
Can't the width/height be forgotten in the request processing when a KML
format is requested ?
Third is a mapscript problem : when I add the KML or KMZ outputformat to
my mapfile, any try to load the mapfile with python mapscript ends up
with a "MapServerError: loadOutputFormat(): General error message.
OUTPUTFORMAT clause references driver KML, but this driver isn't
configured."
mapserv -v gives an OUTPUT=KML and python mapscript has been built and
installed from that version.
Thanks for your help
Guillaume
