[mapserver-dev] WFS 1.1 axis order
Yves Jacolin
yves.jacolin at camptocamp.com
Wed Dec 7 06:12:44 EST 2011
Hello,
here some information:
* I am using MapServer 6.0.1:
MapServer version 6.0.1 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=KML
SUPPORTS=PROJ SUPPORTS=AGG SUPPORTS=CAIRO SUPPORTS=FREETYPE SUPPORTS=ICONV
SUPPORTS=FRIBIDI SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER
SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER SUPPORTS=SOS_SERVER SUPPORTS=FASTCGI
SUPPORTS=THREADS SUPPORTS=GEOS INPUT=POSTGIS INPUT=ORACLESPATIAL INPUT=OGR
INPUT=GDAL INPUT=SHAPEFILE
* data is point.shp
* MapFile that doesn't work : mapfile_notworking.map
* MapFile which is working: mapfile_working.map
Diff is:
14c14
< "wfs_srs" "EPSG:4326 EPSG:27572"
> "wfs_srs" "EPSG:27572 EPSG:4326"
41c41
< "init=epsg:4326"
> "init=epsg:27572"
If I define "init=epsg:27572" to the POI layer (which is wrong) and switch epsg
code for wfs_srs parameter I get the correct data.
If I change only the value of wfs_srs from mapfile_notworking.map nothing is
working.
If I change only the layer projection from mapfile_notworking.map I get strange
data (a kind of grid of point).
Hope it helps.
Thanks,
Y.
Le vendredi 25 novembre 2011 14:52:12, thomas bonfort a écrit :
> Yves,
> please post both mapfiles, and state which mapserver version(s) you are
> using.
> thomas
> On Fri, Nov 25, 2011 at 14:36, Yves Jacolin <yves.jacolin at camptocamp.com>
wrote:
> > Hello,
> > It seems I have an issue with "WFS 1.1 axis order". If I try with a
> > mapfile (let's call it mapfile1) this command line:
> > host?version=1.1.0&SERVICE=WFS&REQUEST=GetFeature&BBOX=-65,-33,59,63&TYPE
> > NAME=layername
> > host?version=1.0.0&SERVICE=WFS&REQUEST=GetFeature&BBOX=-65,-33,59,63&TYP
> > ENAME=layername
> > I get two gml files with x,y coordinates fliped (hope this is the good
> > word). For 1.0.0 I get lat,lon for 1.1.0 I get y,x.
> > If I try with anoter mapfile (let's call it mapfile2 with different
> > layer) I don't get this behaviour.
> > I read the migration guide carefully but I don't find any idea the
> > difference between this two mapfile.
> > Thanks,
> > Y.
> > Responsable Formation et Support
> > Camptocamp France SAS
> > Savoie Technolac, BP 352
> > 73377 Le Bourget du Lac, Cedex
> > Tel (France) : +33 4 79 26 57 98
> > Tel (Suisse) : +41 21 619 1031
> > Mob. : +33 6 18 75 42 21
> > Fax : 04 79 70 15 81
> > Mail : yves.jacolin at camptocamp.com
> > http://www.camptocamp.com
> > mapserver-dev mailing list
> > mapserver-dev at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/mapserver-dev
MAP
NAME WFS_server
STATUS ON
EXTENT -180 -90 180 90
UNITS DD
WEB
# IMAGEPATH et IMAGEURL servent pour les SLD (IMAGEURL apparement ne sert à rien, pointe sur IMAGEPATH)
IMAGEPATH "/var/www/client-maintenance2010/htdocs/yjacolin/client/debug_client.log"
IMAGEURL "http://monhost.camptocamp.com/cgi-bin/wmstest2?"
METADATA
"wfs_title" "client WFS"
"wfs_onlineresource" "http://monhost.camptocamp.com/cgi-bin/wmstest2?"
"ows_enable_request" "*"
"wfs_formats" "GML"
END
END
PROJECTION
"init=epsg:4326"
END
OUTPUTFORMAT
NAME "OGRGML"
DRIVER "OGR/GML"
FORMATOPTION "STORAGE=filesystem"
FORMATOPTION "FORM=multipart"
FORMATOPTION "FILENAME=result.gml"
END
LAYER
NAME "poi"
TYPE POINT
STATUS OFF
DUMP TRUE ## REQUIRED
DATA points_4326
PROJECTION
"init=epsg:4326"
END
METADATA
"wfs_title" "poi" ## REQUIRED
"wfs_name" "poi"
"wfs_srs" "EPSG:4326"
"gml_featureid" "osm_id"
"gml_include_items" "all"
END
END
END
MAP
NAME WFS_server
STATUS ON
UNITS DD
WEB
METADATA
"wfs_formats" "GML"
END
END
PROJECTION
"init=epsg:4326"
END
OUTPUTFORMAT
NAME "OGRGML"
DRIVER "OGR/GML"
END
LAYER
NAME "poi"
TYPE POINT
STATUS OFF
DATA points_4326
PROJECTION
"init=epsg:27572"
END
METADATA
"wfs_name" "poi"
END
END
END
Type: application/x-compressed-tar
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20111207/8e95bee4/points_4326.tar-0001.bin
