[mapserver-dev] msCopyMap ticket issue
Eichner, Andreas - SID-NLKM
Andreas.Eichner at sid.sachsen.de
Tue Dec 20 07:27:08 EST 2011
Hello Thomas,
I just found out that msCopyMap(mapcopy.c) does not copy map.maxsize.
While looking for an open ticket on MS v6.0.1 regarding this issue I saw
that you fixed this in trunk already. But the only ticket I found was
#3669 "MapObj->clone() doesn't copy the MAXSIZE value". Since the
(Python-)MapScript method simply uses msCopyMap your fix resolves this
ticket too.
Would be nice if you could take the ticket #3669 over and mark it as
close.
Thanks,
Andreas
