[mapserver-dev] libtool build: call for vote
thomas bonfort
thomas.bonfort at gmail.com
Thu Dec 22 13:36:54 EST 2011
I have committed the changes in r12907, along with changes to the
builds of python and php mapscript.
building steps:
./configure [previous opts] --prefix=/usr/local
make
sudo make install
cp /usr/local/bin/mapserv [cgi-bin-directory] #do *not* directly copy
the mapserv binary from our top-level source directory, as it is a
wrapper script and not compiled machine code.
python and php mapscript are both built with make && make install. The
other mapscript flavors will probably not compile, I will get back to
them in a second step if no one wants to volunteer on the task.
please report back any issues in this thread or with a trac ticket.
regards,
thomas
On Wed, Dec 21, 2011 at 05:04, Perry Nacionales <pnaciona at gmail.com> wrote:
> +1
> -Perry
> On Tue, Dec 20, 2011 at 8:37 AM, thomas bonfort <thomas.bonfort at gmail.com>
> wrote:
>> I would like to call for a vote on the recent discussion regarding the
>> switch to libtool.
>> Given the reticences regarding the blackbox behavior libtool, I will
>> commit to implementing a --with(out)-libtool switch to our configure
>> script should issues arise with the libtool builds. Note that in that
>> case I will *not* be supporting building a dso module.
>> +1
>> thomas
>> mapserver-dev mailing list
>> mapserver-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
