[mapserver-dev] Displaying the msautotest failures on Windows
Lime, Steve D (DNR)
Steve.Lime at state.mn.us
Tue Feb 1 10:18:32 EST 2011
Thanks for doing this, it's very, very convenient... Now if you can make it possible to view a single test across multiple build environments so you can see where things went south... ;-)
Steve
________________________________________
From: mapserver-dev-bounces at lists.osgeo.org [mapserver-dev-bounces at lists.osgeo.org] On Behalf Of Tamas Szekeres [szekerest at gmail.com]
Sent: Sunday, January 30, 2011 9:33 AM
To: mapserver-dev at lists.osgeo.org
Subject: [mapserver-dev] Displaying the msautotest failures on Windows
Folks,
I've made some effort to visualize the results of the msautotest steps executed regularly on Windows by the build system at http://vbkto.dyndns.org/sdk/
You may inspect the failures on various combinations of the compilers, architectures and mapserver versions by clicking on the corresponding 'msautotest' link.
It would be helpful if you could take a look at the results in detail and figure out how the various problems could be fixed up.
Some of the tests may provide slightly different result on Windows, which may be a correct result however. I wonder if we could establish an option to store multiple variations of the expected results in autotest depending on the OS versions, whatever.
Best regards,
Tamas
