[mapserver-dev] RFC 67 - Enable/Disable Layers in OGC Web Services
Lime, Steve D (DNR) Steve.Lime at state.mn.us
Mon Feb 14 09:44:30 EST 2011
I was thinking the same thing. Thanks for pulling these Jeff. The idea back then was to be explicit with the OWS configs, hence their own object.
Steve
________________________________________
From: mapserver-dev-bounces at lists.osgeo.org [mapserver-dev-bounces at lists.osgeo.org] On Behalf Of Jeff McKenna [jmckenna at gatewaygeomatics.com]
Sent: Monday, February 14, 2011 8:43 AM
To: mapserver-dev at lists.osgeo.org
Subject: Re: [mapserver-dev] RFC 67 - Enable/Disable Layers in OGC Web Services
Hi guys,
I just fell upon our old notes from the 2009 code sprint, and in it
contains the example on how we proposed during that meeting to solve
this hiding services issue:
   LAYER
     OWS
        SERVICE
          TYPE WMS
          REQUESTS ALL # ALL, ONE, or specific request to accept for
this layer
          "key1" "value1"
          "key2" "value2"
        END
        SERVICE
          TYPE WFS
          REQUESTS ...
        END
     END
   END
http://trac.osgeo.org/mapserver/wiki/TorontoCodeSprint2009Notes
Is there a reason to use metadata instead of the above?
-jeff
On 11-02-10 4:11 PM, Jeff McKenna wrote:
> Hello Alan, Daniel, and Assefa,
> Thanks for putting together this RFC, for this much-needed enhancement.
> I must say that I am impressed with the elaborate solution proposed. As
> I was reading it I had some questions about what-overrides-what, but I
> see that is covered in the 'Inheritance' section. Regarding disabling
> all services by default, I totally agree with this and now is the time
> to make this change. It just puts pressure on the documentation to make
> sure it is explained well :)
> -jeff
> On 11-02-09 10:18 PM, Alan Boudreault wrote:
>> Hi devs,
>> Daniel, Assefa and I worked on the ability to enable/disable layers in
>> OGC Web
>> Services. We tried to choose the easiest solution from a user point of
>> view.
>> We would like to get this for the release 6.0.
>> http://mapserver.org/development/rfc/ms-rfc-67.html
>> Let us know your comments and thoughts.
mapserver-dev mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-dev
