[mapserver-dev] Closing a layer removes class expressions and
texts (bug or feature?)
Lime, Steve D (DNR)
Steve.Lime at state.mn.us
Mon Feb 28 10:24:53 EST 2011
Tamas: Do you have a test script that demonstrates the parsing error you run into? I’ll make this a priority to fix tonite.
Steve
From: mapserver-dev-bounces at lists.osgeo.org [mailto:mapserver-dev-bounces at lists.osgeo.org] On Behalf Of Tamas Szekeres
Sent: Sunday, February 27, 2011 1:28 PM
To: Frank Warmerdam
Cc: mapserver-dev at lists.osgeo.org
Subject: Re: [mapserver-dev] Closing a layer removes class expressions and texts (bug or feature?)
Frank,
Further problem is that if I comment out the related code in msLayerClose, the second attempt of parsing the same expression will fail (msEvalExpression). I have no clues to get this stuff working at all :-(
Best regards,
Tamas
2011/2/27 Frank Warmerdam <warmerdam at pobox.com<mailto:warmerdam at pobox.com>>
On 11-02-27 02:03 PM, Tamas Szekeres wrote:
Hi All,
The current implementation in msLayerClose (maplayer.c line 215-216 in trunk)
removes the expression and text for each class of the corresponding layer. I
doubt if it was a good practice since the second draw of the same map object
yieds different rendering result. Could someone explain how does this addition
make sense?
IMHO the drawing process itself should not alter the map configuration
specified by the user.
Tamas,
There is a ticket on this and I believe Steve will address it shortly once
he better understands why he did it this way in the first place.
http://trac.osgeo.org/mapserver/ticket/3692
It is also breaking some stuff for me.
Best regards,
I set the clouds in motion - turn up | Frank Warmerdam, warmerdam at pobox.com<mailto:warmerdam at pobox.com>
light and sound - activate the windows | http://pobox.com/~warmerdam<http://pobox.com/%7Ewarmerdam>
and watch the world go round - Rush | Geospatial Programmer for Rent
mapserver-dev mailing list
mapserver-dev at lists.osgeo.org<mailto:mapserver-dev at lists.osgeo.org>
http://lists.osgeo.org/mailman/listinfo/mapserver-dev
URL: http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20110228/21cb7ffb/attachment.html
