[mapserver-dev] Oracle CURVEPOLYGON draw Error
    ow33rt5
    olivierweerts at gmail.com
    Wed Jan 12 08:26:12 EST 2011
I'm posting this message because i'm having some problems with the drawing
of geometries in map server.
I'm using oracle spatial 11g with a table that contains different kind of
Geometries (POLYGON, CURVEPOLYGON, GEOMETRYCOLLECTION) and the mapfile
(shown hereunder) used for rendering those geometries is of type POLYGON.
The problem is that with some geometries (CURVEPOLYGON) i'm getting the
following error message: msDrawShape(): General error message. Only polygon
shapes can be drawn using a POLYGON layer definition.
I have tried to change the type of the mapfile from POLYGON to LINE and then
the geometry is rendered except that i'm using a hatchline style and only
the border of the geometry is drawn (no hatchlines anymore).
A way to solve the problem is to create two mapfiles (one with POLYGON style
and one with LINE and filtered the query with the geometry type) but as the
geometries that cause the problem are of type CURVEPOLYGON i was asking
myself if there wasn't a way to render it in a POLYGON type mapfile.
And if it's not possible is there's a way to render hatchlines in a LINE
type.
I am currently using mapserver 5.6.5 and the problem seems to ccured since i
have migrated from version 5.4 to the current one.
Can anyone help?
Thanks in advace,
Olivier.
the mapfile code:
LAYER
	NAME "element_demande_autre"
	GROUP element_demande
	CONNECTIONTYPE oraclespatial
	INCLUDE "includes/connectionstring.map"
	STATUS ON
	TYPE POLYGON
	LABELITEM "LABEL"
	LABELMAXSCALEDENOM 5000
	MAXSCALEDENOM 10000
	PROCESSING "CLOSE_CONNECTION=DEFER"
	TEMPLATE templates/template_demande/template_demande.html
	HEADER templates/template_demande/template_demande_autre_header.html
	FOOTER templates/template_footer.html
	DATA "GEOMETRIE_BUFFER FROM (SELECT D.ID,D.GEOMETRIE_BUFFER,
D.STATUT_COMMISSION_LABEL, D.COD_MAE,D.COD_SOUSMESURE_OPTION,
D.COD_EXPLOITANT, D.TYPE_SAISIE_INSTRUCTION , D.STATUT_COMMISSION,
D.COD_EXPLOITANT || '/' ||  D.COD_MAE || '/' || D.COD_SOUSMESURE_OPTION
LABEL, ROUND(SDO_GEOM.SDO_AREA(D.GEOMETRIE_BUFFER,0.001,'unit=SQ_M')/100, 2)
AREA FROM ELEMENT_DEMANDE_V_S D WHERE D.COD_CAMPAGNE = %COD_CAMPAGNE% AND
D.COD_EXPLOITANT != %COD_EXPLOITANT% AND ((('%TYPE_DEM_MES_CTRL%' = '0') OR
(('%TYPE_DEM_MES_CTRL%' != '0') AND (D.TYPE_SAISIE_INSTRUCTION != '0') AND
(D.STATUT_COMMISSION IS NULL OR D.STATUT_COMMISSION != '2') )) )) USING
UNIQUE ID SRID 26273 VERSION 10g"
	CLASS
		NAME 'Dem. autres Expl. et MAE'
		#EXPRESSION   ((("%TYPE_DEM_MES_CTRL%" = "0") || (("%TYPE_DEM_MES_CTRL%" =
"1") && ("[TYPE_SAISIE_INSTRUCTION]" != "0") && ("[STATUT_COMMISSION]" !=
"2") )) && ((("[TYPE_SAISIE_INSTRUCTION]" = "0") &&
("%TYPE_SAISIE_INSTR_CTRL%" = "0")) || (("[TYPE_SAISIE_INSTRUCTION]" != "0")
&& ("%TYPE_SAISIE_INSTR_CTRL%" = "1"))))
		STYLE
		COLOR 255 165 0
		OUTLINECOLOR 255 165 0
			SYMBOL 'hatchline'
			ANGLE 0
			SIZE 30
			WIDTH 1
		END
		STYLE
			symbol 'pointligne'
			size 2
		END
		LABEL
			antialias TRUE
			TYPE truetype
			OUTLINECOLOR 0 0 0
			FONT "arialbd"
			SIZE 10
			COLOR 255 165 0
			POSITION uc
			PARTIALS true
			FORCE true
		END
	END
END
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Oracle-CURVEPOLYGON-draw-Error-tp5914498p5914498.html
Sent from the Mapserver - Dev mailing list archive at Nabble.com.
URL: http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20110112/fe191cda/attachment-0001.html
