[mapserver-dev] Quote escaping in mapfile strings
Lime, Steve D (DNR) Steve.Lime at state.mn.us
Wed Jan 12 11:15:33 EST 2011
6.0 will require a more general approach anyway. Thinking back you're right that Umberto's work was limited to logical
expressions. The parser upgrade really makes that work obsolete since we don't substitute before parsing anymore. So
in 6.0 if a expression is like so:
  ('[somevar]' = 'a string')
and the a particular value in column somevar contains O'Brien we don't have to do anything special anymore. The column
data is accessed outside the context of the expression string representation.
I think this is a much easier problem than what Umberto had to work around... I'd like to help but it will be this weekend
before I have any time.
Steve
________________________________________
From: mapserver-dev-bounces at lists.osgeo.org [mapserver-dev-bounces at lists.osgeo.org] On Behalf Of Daniel Morissette [dmorissette at mapgears.com]
Sent: Wednesday, January 12, 2011 6:53 AM
To: mapserver-dev at lists.osgeo.org
Subject: Re: [mapserver-dev] Quote escaping in mapfile strings
Thanks for the pointers. It seems that this would have been in place
since 5.0, but only for expression strings (strings inside logical
expressions) and not for static strings.
I guess I'll have a look at what it would take to support this in static
strings as well, unless one of the lexer experts is a taker?
Daniel
On 11-01-12 04:13 AM, thomas bonfort wrote:
> Yes, it seems Steve has added that very recently, but I haven't tested it yet.
> Steve has chosen C style \ escaping and am supportive of this idea. I
> would be -0 on the second escaping technique as to me it seems more
> convoluted and less intuitive: imho taking a burden off windows users
> is fine unless it puts a burden on traditional *nix users.
> best regards,
> thomas
> On Wed, Jan 12, 2011 at 09:25, Umberto Nicoletti
> <umberto.nicoletti at gmail.com>  wrote:
>> Daniel,
>> I think we are already using the first approach in the mapfile to
>> escape quotes, see maplexer.l lines 534 to 577.
>> Regards,
>> Umberto
>> On Wed, Jan 12, 2011 at 5:10 AM, Daniel Morissette
>> <dmorissette at mapgears.com>  wrote:
>>> An issue that keeps coming back every once in a while is the lack of a
>>> mechanism to escape quotes (') and double quotes (") inside strings in
>>> mapfiles.
>>> 6.0 would be a good time to address this in case the fix implies new mapfile
>>> rules or limitations.
>>> The first step is to decide on the syntax to escape quotes. Can anyone think
>>> of a magic solution to this problem that will make everybody happy?
>>> Here are a few thoughts:
>>> 1- An obvious approach could be to use C escaping: \' , \" and \\ ... but
>>> unfortunately that would force the use of double \\ in all windows filename
>>> paths. I realize that one could use "/" on Windows instead but using this
>>> approach could cause unnecessary confusion with beginners and become a FAQ
>>> that comes up more often than the use dummy TEMPLATEs to enable queries in
>>> MapScript.
>>> 2- Another approach could be to use two double quotes ("") to escape a
>>> double quote, and two single quotes ('') to escape a single quote
>>> e.g.
>>>   "This string contains ""Double Quotes"""
>>>   'This string contains ''Single Quotes'''
>>>   "You don't need to escape single quotes in this string since it uses double
>>> quotes ("") as delimiter"
>>>   'And the same way "Double Quotes" don't need escaping here'
>>>   "Two ''single quotes'' in this string are not considered an escape sequence
>>> and remain two individual chars'
>>> /me thinks #2 could work with a minimum of disruption to existing mapfiles,
>>> unless I missed something. We'd need Steve's opinion on how this can be
>>> implemented in the parser.
>>> Anyone have better suggestions?
>>> Daniel
>>> Daniel Morissette
>>> http://www.mapgears.com/
>>> mapserver-dev mailing list
>>> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
Daniel Morissette
