[mapserver-dev] RFC 66 - Better handling of temporary files
Daniel Morissette
dmorissette at mapgears.com
Fri Jan 14 06:55:25 EST 2011
On 11-01-14 03:25 AM, thomas bonfort wrote:
> are there valid reasons for not using mktemp (or even better mkstemp,
> but that returns a file handle, maybe the mapserver functions require
> a file name) ?
I remember that's been discussed a while ago and had forgotten the
reasons. I did a search and found only one ticket that talks about the
possibility of using mkstemp():
http://trac.osgeo.org/mapserver/ticket/1322
It seems that a switch to mkstemp() was ruled out at that time because
of release timing and then the original issue was successfully fixed we
never came back to that question.
Perhaps we could review the code that uses msTmpFile() and see if a
switch to mkstemp() (and GetTempFileName() on Windows) would be
possible. We may find that some places require a filename that is later
passed to other libs, or that the temp filename needs to carry a
specific extension... but maybe not.
Can you please investigate that Alan?
Daniel Morissette
http://www.mapgears.com/
