[mapserver-dev] MapServer 5.6.6 release
Daniel Morissette
dmorissette at mapgears.com
Fri Jan 14 15:36:27 EST 2011
Hi Assefa, and all,
I have packaged a RC2 with your the latest fixes:
http://download.osgeo.org/mapserver/mapserver-5.6.6-rc2.tar.gz
Daniel
On 11-01-14 01:44 PM, Yewondwossen Assefa wrote:
> Daniel,
> Is it possible to prepare an RC-2. There were 2 fixes this morning just
> after RC-1 has been prepared.
> Thanks
> On 14/01/2011 10:07 AM, Daniel Morissette wrote:
>> Hi PSC,
>> I see that the OSGeo Live DVD team is planning its feature freeze for
>> Jan 31st, and to make sure the version of MapServer that is included
>> will contain the latest fixes, I propose that we release MapServer
>> 5.6.6 with what is currently in SVN branch-5-6 which includes some
>> important fixes, a copy of the list is included below.
>> I have packaged a 5.6.6-rc1 for testing:
>> http://download.osgeo.org/mapserver/mapserver-5.6.6-rc1.tar.gz
>> Please test it and report your results here. I'd like to post the
>> 5.6.6 release on Monday if we have enough positive feedback results by
>> then, otherwise that would have to wait until Jan 27-28 since I'll be
>> away from Jan 18 to 26.
>> I start with my +1 to release 5.6.6 based on this 5.6.6-rc1.
>> Daniel
>> Change log for MapServer 5.6.6:
>> - Fixed missing time in msDrawMap logging (#3651)
>> - Fixed Internal error with Oracle Spatial multi point geometries (#3627)
>> - Fixed double free in shp2img.c (#3497)
>> - Fixed free(): invalid next size in mapfile.c (#3604)
>> - Fix for the memory corruption when mapping the string data type in
>> the Java bindings (3491)
>> - Correct wms 1.3.0 latlong bbox error (#2578)
>> - Fix ProperyIsLike not used efficiently with Oracle (#3557)
>> - Fixed msOGRGetSymbolId according to the changes in gdal 1.8 (#3556)
>> - Fixed crash when drawing a map using UNIQUE fid in the layer data
>> (#3271)
>> - Fixed Oracle Spatial Data gets corrupt (#3541)
>> - Fixed issue with multiple styles and binding (#3538)
>> - Fixed multiple include tags not supported in xml mapfiles (#3530)
>> - Ensure the class is not marked BeforeFieldInit causing memory
>> corruption with C#/CLR4 (#3438)
>> - Fixed MSSQL2008 driver returning invalid extent (#3498)
>> - Fix computation of shape bounds when the first line contains no points
>> (#3119)(fixes #3383)
>> - Fixed error message tiles on zero-sized map cause memory allocation
>> errors in maperror.c. (#3524)
>> mapserver-dev mailing list
>> mapserver-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
Daniel Morissette
http://www.mapgears.com/
