[mapserver-dev] RFC 66 - Better handling of temporary files
Stephen Woodbridge
woodbri at swoodbridge.com
Fri Jan 14 17:51:20 EST 2011
In general I like the idea of having options to control things like
this. I also like the default behavior to just do the right thing
whatever that is so most users do not need to worry themselves over it.
I think we have discussed this in the past, but it makes a lot of sense
so new users do not have to worry about all these things to get
something up and running. It is kind of like having and expert tab that
allows you to change parameters that most people never need to change.
On some sites that have a need to configure these things for ultra high
end performance that need the ability to customize the configuration,
you need access to these things. Another potential use would be
configuring a bootable DVD to run mapserver, then you might want to
configure the temp files to be at a specific location. Anyway, I see
these as needed exceptions to the normal operations.
We might also want to consider flagging these options in the
documentation "Expert Only" features with an appropriate explanation of
what we mean by that.
I think we need to keep in mind the "Out of the Box" experience and at
the same time not cut off our noses to spite our face.
My 2cts,
-Steve
On 1/14/2011 4:42 PM, thomas bonfort wrote:
> On Fri, Jan 14, 2011 at 22:23, Frank Warmerdam<warmerdam at pobox.com> wrote:
>> On 11-01-14 07:46 AM, thomas bonfort wrote:
>>> Jeff,
>>> I don't like TEMPPATH because it should not be necessary for a user to
>>> have to configure it. On unix, there is a system function that will
>>> guarantee to create you a temp file without having to make the
>>> assumption it will be in /tmp, and I imagine it could be possible to
>>> implement something similar for windows if it doesn't exist.
>>> Let's not burden our users with setting a configuration variable for
>>> something that is system related and should be taken care of
>>> transparently.
>> Thomas,
>> I like the idea of being able to control where my MapServer temp
>> files are created - either so I can keep them separate from system
>> temporary files, or so I can control what drive they are on (ie.
>> ram drive, extra physical drive). But it might be nice if the
>> *fallback* when it isn't set is to do the normal system behavior.
> Frank,
> as a developer, I agree that knowing where the temp file is created so
> you can inspect what is going on is a definitive plus. As a user, I
> don't see the point, and would especially not want to have to
> configure it.
> I'm +1 for a default system call if TEMPPATH is not specified and use
> whatever defined value if the user has gone to the trouble of
> specifying it, and against having a log message
> be output if TEMPPATH is not set.
> My initial concern is that we seem to be reinventing the wheel in
> regards to tempfile creation, whereas there are secure and tested
> solutions with mkstemp that we should at least investigate before
> rolling out our own.
> best regards,
> thomas
> ps. I hope the tone is not harsh or condescending, its not my aim in any way.
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
