[mapserver-dev] [Oracle] Query filter
Guillaume BARTHE
guillaume.barthe at c-s.fr
Tue Jan 18 07:24:47 EST 2011
I think it's an oracle bug because :
DATA "VGEO FROM (SELECT * FROM TABLE(PK_TEST.FILTRER(33,36))) USING
NONE; works.
I use Oracle 10.2.0.3-0 :
SELECT * FROM TABLE(PK_TEST.FILTRER(33,36)); ==> OK !
SELECT * FROM TA_GEOATTRIBUTE_VALUE WHERE AGEOATTRIBUTE_VALUE_ID BETWEEN
33 AND 36; ==> OK !
SELECT ROWNUM, VGEO FROM (SELECT * FROM TABLE(PK_TEST.FILTRER(33,36)));
==> OK !
SELECT ROWNUM, VGEO FROM (SELECT * FROM TA_GEOATTRIBUTE_VALUE WHERE
AGEOATTRIBUTE_VALUE_ID BETWEEN 33 AND 36); ==> OK !
AGEOATTRIBUTE_VALUE_ID BETWEEN 33 AND 36) WHERE ROWNUM = 1; ==> OK !
AGEOATTRIBUTE_VALUE_ID BETWEEN 33 AND 36) WHERE SDO_FILTER( VGEO,
NULL,'querytype=window') = 'TRUE'; ==> OK !
WHERE SDO_FILTER( VGEO, NULL,'querytype=window') = 'TRUE'; ==> NOK :
ORA-00600: internal error code, arguments: [koksccd1], [0], [], [], [],
00600. 00000 - "internal error code, arguments: [%s], [%s], [%s], [%s],
[%s], [%s], [%s], [%s]"
*Cause: This is the generic internal error number for Oracle program
exceptions. This indicates that a process has encountered an
exceptional condition.
*Action: Report as a bug - the first argument is the internal error number
Guillaume
Guillaume BARTHE a écrit :
> Hi,
> I try interface mapserver and oracle with stored procedure like :
> SRID 4326 VERSION 10g"
> Mapserver return :
> msDrawMap(): Image handling error. Failed to draw layer named 'sipad'.
> msOracleSpatialLayerWhichShapes(): OracleSpatial error. Error:
> [], [], [], [] . Query statement: SELECT rownum, VGEO FROM (SELECT *
> FROM TABLE(PK_TEST.FILTRER(33,36))) WHERE SDO_FILTER( VGEO,
> MDSYS.SDO_GEOMETRY(2003, :srid,
> NULL,MDSYS.SDO_ELEM_INFO_ARRAY(1,1003,3),:ordinates
> ),'querytype=window') = 'TRUE' . Check your data statement.
> This syntax is a standart oracle, why mapserver doasen't permit it ?
> Thank you for answering.
> Guillaume
> <www.c-s.fr> *Guillaume BARTHE*
> Ingénieur d'étude sur KHEPER
> *CS Systèmes d'Information - Division Espace & Renseignement*
> Département Information Géographique & Image
> Parc de la Grande Plaine - 5, Rue Brindejonc des Moulinais - BP 15872
> 31506 Toulouse Cedex 05 - FRANCE
> Tel : +33 561 17 63 70
> Email : guillaume.barthe at c-s.fr
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
Skipped content of type multipart/related
