[mapserver-dev] Re: RFC for XMP metadata support
Paul Ramsey pramsey at opengeo.org
Thu Jul 7 13:04:09 EDT 2011
Re-sending to list...
On Thu, Jul 7, 2011 at 9:41 AM, Paul Ramsey <pramsey at opengeo.org> wrote:
> On Thu, Jul 7, 2011 at 8:45 AM, Daniel Morissette
> <dmorissette at mapgears.com> wrote:
>> Hi Paul,
>> Here are a few questions/comments:
>> - The proof of concept code attached to ticket #3932 is executed in all
>> cases. The real implementation should be conditional to the presence of
>> xmp_* metadata to avoid calling xmp_init() and reopening the output file
>> unnecessarily when this feature is not used. (I presume you were going to do
>> that already but that was not explicitly stated in the RFC)
> Correct, the PoC really only proved to me that (a) yes I could get a
> license in there and (b) the build system could be altered w/o too
> much trouble. So yes, much more work to do there.
>> - Instead of focusing on license metadata, could we not make it so that any
>> xmp_* metadata triggers this feature and ends up writing the corresponding
>> metadata to the output?
> I think that's a reasonable generalization, once one has committed to
> supporting xmp anyways.
>> - As Thomas already pointed out, it would be ideal to have support for this
>> via the default output formats as well and not just GDAL based formats
> I'll look again and try to find a place to insert this processing that
> doesn't do too much harm to the overall mapserver code.
> P.
>> Daniel
>> On 11-07-07 11:29 AM, Paul Ramsey wrote:
>>> No concerns, questions?
>>> On Mon, Jul 4, 2011 at 9:10 AM, Paul Ramsey<pramsey at cleverelephant.ca>
>>>  wrote:
>>>> Devs,
>>>> I've prepared a draft RFC for adding embedded metadata into output
>>>> images produced by MapServer.
>>>>  http://trac.osgeo.org/mapserver/attachment/ticket/3932/ms-rfc-7X.txt
>>>> I'm looking for feedback now before I number and commit it and ask for
>>>> a vote. Here's the preamble so you don't have to click:
>>>> XMP is the "extensible metadata platform" [1]_ which allows the
>>>> embedding of metadata information across a wide range of document and
>>>> image formats: PNG, GIF, JPEG, PDF, etc. XMP was originally developed
>>>> by Adobe [2]_ and is supported across their product line. It is now
>>>> being increasingly included in other standards for metadata embedding
>>>> and supported by tools for viewing image information (e.g. exiftools).
>>>> Creative Commons has standards for using XMP to embed commons
>>>> licensing [3]_ in images and other document, including a specific
>>>> creative commons schema. One of the challenges of advertising
>>>> licensing and terms of use in WMS and other web mapping services is
>>>> that the terms are usually advertised separately from the actual
>>>> content. So a WMS service might specify terms in the Capabilities
>>>> document, but the images themselves will be unmarked. Embedding
>>>> license URLs inside the images themselves using a standard marking
>>>> allows organizations to be unambiguous about the conditions attached
>>>> to their content.
>>>> The goal of this change is to allow users the option of embedding XMP
>>>> metadata in their MapServer output using an open source XMP utility
>>>> library.
>>>> .. [1] http://en.wikipedia.org/wiki/Extensible_Metadata_Platform
>>>> .. [2] http://www.adobe.com/products/xmp/overview.html
>>>> .. [3] http://wiki.creativecommons.org/XMP
>>>> .. [4] http://libopenraw.freedesktop.org/wiki/Exempi
>>>> Thanks,
>>>> Paul
>>> mapserver-dev mailing list
>>> mapserver-dev at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
>> Daniel Morissette
>> http://www.mapgears.com/
>> Provider of Professional MapServer Support since 2000
