[mapserver-dev] OGR autostyle font mapping problem
Daniel Morissette
dmorissette at mapgears.com
Wed Jun 1 10:06:41 EDT 2011
FYI there was ticket #1908 about supporting spaces in font names, and a
suggestion to use quotes to allow spaces in font names. Ticket #1908 was
closed 'wontfix' because the original issue with spaces in SVG fonts is
no longer relevant in 6.0, but we could reopen if necessary.
On 11-05-31 12:21 PM, Lime, Steve D (DNR) wrote:
> We need a smarter fontset parser or format so that values can be quoted like within a mapfile. What exists
> now is a very basic reader...
> Steve
> ________________________________________
> From: mapserver-dev-bounces at lists.osgeo.org [mapserver-dev-bounces at lists.osgeo.org] On Behalf Of Jeff McKenna [jmckenna at gatewaygeomatics.com]
> Sent: Friday, May 27, 2011 3:23 PM
> To: mapserver-dev at lists.osgeo.org
> Subject: Re: [mapserver-dev] OGR autostyle font mapping problem
> On 11-05-27 4:46 PM, Tamas Szekeres wrote:
>> Hi All,
>> I've run into the problem with OGR autostyle and font names containing
>> spaces. See http://trac.osgeo.org/mapserver/ticket/3893 for a more
>> detailed description, proposed patch and sample files.
>> Strictly speaking, I wonder if I was the first one who has encountered
>> this problem... Do we have any trivial workaround, that didn't come to
>> my mind before creating the patch? ;-)
>> Or should this issue be considered as an enhancement or defect (to be
>> backported to the stable branch as well)?
> The issue of font names with spaces came up recently on IRC in
> #mapserver and I was also surprised that this problem exists. I'm not
> sure if it exists as a ticket yet, but your ticket should probably
> handle this (note: I'm not referring to the specific case of styleitem
> auto, but all cases of spaces in fontset files).
> -jeff
> Jeff McKenna
> MapServer Consulting and Training Services
> http://www.gatewaygeomatics.com/
> mapserver-dev mailing list
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
Daniel Morissette
http://www.mapgears.com/
Provider of Professional MapServer Support since 2000
