[mapserver-dev] RFC 72: Adding GEOMTRANSFORM to Layer/Label
Objects
Brent Fraser
bfraser at geoanalytic.com
Thu Jun 30 10:38:03 EDT 2011
Steve,
Very exciting! My main use-case would be for labeling rivers "above"
the rivers. I see that GEOS has implemented a SingleSideBuffer /
OffsetCurve, which may help in the implementation (could be a challenge
with interpreting left/right vs above/below though).
Performance could be a problem when requesting features from a large
datastore since the spatial filter needs to be applied to the buffered
feature. Perhaps expanding the MBR of the spatial fliter by the buffer
value would be a solution...
Best Regards,
Brent Fraser
On 6/29/2011 10:21 PM, Lime, Steve D (DNR) wrote:
> Hi All: I've started work on a proposal to extend logical expressions that include GEOS operators like buffer and difference to layer/label-levels. I think there could be some pretty neat uses for such functionality. Should be online shortly at:
> http://www.mapserver.org/development/rfc/ms-rfc-72.html
> Comments welcome...
> Steve
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
