[mapserver-dev] WMS 1.3 GetFeatureInfo
Bart van den Eijnden
bartvde at osgis.nl
Tue Mar 8 18:35:52 EST 2011
Hi devs,
how was WMS GetFeatureInfo implemented in Mapserver for WMS 1.3?
Does I and J follow the axis order like it says in the spec?
7.4.3.7 I, J
The mandatory I and J request parameters are integers that indicate a point of interest on the map that was produced by the embedded GetMap request (the “map request part” described in 7.4.3.3). The point (I,J) is a point in the (i,j) space defined by the Map CS (see 6.7.2). Therefore:
⎯ the value of I shall be between 0 and the maximum value of the i axis; ⎯ the value of J shall be between 0 and the maximum value of the j axis; ⎯ the point I=0, J=0 indicates the pixel at the upper left corner of the map; ⎯ I increases to the right and J increases downward.
The point (I,J) represents the centre of the indicated pixel. If the value of I or of J is invalid, the server shall issue a service exception (code = InvalidPoint).
Best regards,
Bart
Looking for flexible support on OpenLayers or GeoExt? Please check out http://www.osgis.nl/support.html
OSGIS
bartvde at osgis.nl
URL: http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20110309/8cc67889/attachment.html
