[mapserver-dev] shp2img exit status
Peter Hopfgartner peter.hopfgartner at r3-gis.com
Fri Mar 18 05:06:53 EDT 2011
I can do something on this, maybe over the weekend. Should the exit code be simply "1" or should a constant/macro be defined in mapserver.h for this, like MS_EXIT_ERROR/MS_EXIT_OK ?
Peter Hopfgartner
R3 GIS Srl - GmbH
http://www.r3-gis.com
--------Frank Warmerdam <warmerdam at pobox.com> wrote--------
Subject: Re: [mapserver-dev] shp2img exit status
Date: 17.03.2011 14:44
>On 11-03-17 12:39 AM, Peter Hopfgartner wrote:
>> Looking through the source of shp2img, it seems that exit status 0 is
>used even when an error was encountered, see lines 133, 142, 246, 274,
>305. I guess the same is true for other file executables. Should I create
>a ticket for this?
>Peter,
>Yes, I think this is worth filing a ticket though I'm not sure when we
>will address it.  A ticket with a patch would of course have more rapid
>effect.  I did confirm mapserv has a similar problem.
>Best regards,
>I set the clouds in motion - turn up   | Frank Warmerdam,
>light and sound - activate the windows | http://pobox.com/~warmerdam
>and watch the world go round - Rush    | Geospatial Programmer for Rent
>_______________________________________________
>mapserver-dev mailing list
>mapserver-dev at lists.osgeo.org
>http://lists.osgeo.org/mailman/listinfo/mapserver-dev
