[mapserver-dev] Fwd: RE: [FriBidi] Incorrect Arabic text rendering in maperver
Lime, Steve D (DNR) Steve.Lime at state.mn.us
Tue Mar 22 10:02:10 EDT 2011
Can you create a ticket so this gets in 6.0? -Steve
-----Original Message-----
From: mapserver-dev-bounces at lists.osgeo.org [mailto:mapserver-dev-bounces at lists.osgeo.org] On Behalf Of Stephen Woodbridge
Sent: Monday, March 21, 2011 8:27 PM
To: mapserver-dev
Subject: [mapserver-dev] Fwd: RE: [FriBidi] Incorrect Arabic text rendering in maperver
Hmmm, I just realized this never make it to the dev list.
-Steve W
-------- Original Message --------
Subject: RE: [FriBidi] Incorrect Arabic text rendering in maperver
Date: Sun, 13 Mar 2011 03:40:52 -0400
To: Stephen Woodbridge <woodbri at swoodbridge.com>
CC: Behdad Esfahbod <behdad.esfahbod at gmail.com>, <mapserver-devs at lists.osgeo.org>
Stephen,
Attached is the modified mapserver mapstring.c file which includes changes based on your code snippet.
We have tested this today in our configuration and this solves the issue we had.
I have not previous submitted a change so I am not sure what the process is.
Regards
Ian
From: Stephen Woodbridge [mailto:woodbri at swoodbridge.com]
Sent: Saturday, March 12, 2011 7:35 PM
To: Ian Walberg
Subject: Re: [FriBidi] Incorrect Arabic text rendering in maperver
Ian,
I'm have not followed all of this thread, but from what I have gathered,
  the mapserver code needs to walk over the string and remove these characters which seems reasonable.
So if you are up to making a patch to mapserver and attaching that to a
  the bug you opened, we can see if we can get it reviewed and added to
  6.0 which just went to beta.
FRIBIDI_CHAR_FILL is evidently a three byte sequence if I recall from an
  earlier post on this thread.
  > Also does FRIBIDI_CHAR_FILL get converted to a single utf8 character?
  > What is its value?
\xef\xbb\xbf.
This is untested, but I think something like this should work to remove the FRIBIDI_CHAR_FILL character sequences. You will need to adapt it to the mapserver code.
/* scan str and compress out FRIBIDI_CHAR_FILL UTF8 characters */ if (utf8) {
    len = strlen(str);
    for (i=0, j=0; i<len; i++, j++) {
      if (str[i] == '\xef' && str[i+1] == '\xbb' && str[i+2] == '\xbf')
        i += 3;
      if (i != j) str[j] = str[i];
    str[j] = '\0';
-Steve W
On 3/12/2011 7:04 PM, Behdad Esfahbod wrote:
> On 03/09/11 14:08, Ian Walberg wrote:
>> Behdad,
> Hello,
>> We are back looking at this again and have tried a few combinations and none seem to work.
>> Here is the test change we made to fribidi-arabic.c
>> for (i = 0; i<  len - 1; i++) {
>>      register FriBidiChar c;
>>      if (FRIBIDI_LEVEL_IS_RTL(embedding_levels[i])&&
>>          embedding_levels[i] == embedding_levels[i+1]&&
>>          (c = PAIR_MATCH(table, size, str[i], str[i+1])))
>>          /* str[i] = FRIBIDI_CHAR_FILL; */ // Do we need to remove
>> this next line as well?
>>          FRIBIDI_SET_BITS(ar_props[i], FRIBIDI_MASK_LIGATURED);
>>          /* str[i+1] = c; */
>>          str[i] = c;
> I suggest instead of changing the FriBidi code you simply walk over
> the output string and remove the filler character.
> behdad
>> The assumption is that we would make the 'real' change to mapserver and not here.
>> Thanks
>> Ian
