[mapserver-dev] msautotest crashing on Windows
Tamas Szekeres szekerest at gmail.com
Tue Mar 22 11:44:51 EDT 2011
Yes it seems to fix the problem.
Best regards,
Tamas
2011/3/21 Daniel Morissette <dmorissette at mapgears.com>
> Could Stephan's fix of a double free earlier today also fix this?
> http://trac.osgeo.org/mapserver/changeset/11294
> On 11-03-21 11:30 AM, Alan Boudreault wrote:
>> Emm, these urls work fine on linux. Could anyone pass a valgrind or a gdb
>> on
>> Windows to see where's the problem?
>> Thanks,
>> Alan
>> On March 20, 2011 06:20:20 pm Tamas Szekeres wrote:
>>> Alan,
>>> Here are some examples:
>>> mapserv QUERY_STRING="map=sos.map&service=SOS&version=1.0.0"
>>> (msautotest\wxs\)
>>> mapserv QUERY_STRING="map=rfc36.map&mode=nquery&layer=popplace"
>>> (msautotest\misc\)
>>> mapserv QUERY_STRING="map=rfc36_ogr.map&mode=nquery&layer=popplace"
>>> (msautotest\misc\)
>>> mapserv
>>> QUERY_STRING="map=sos.map&SERVICE=SOS&VERSION=1.0.0&REQUEST=GetCapabilities
>>> &updatesequence=f" (msautotest\wxs\)
>>> mapserv
>>> &acceptversions=0.0.31,0.1.4,1.0.0" (msautotest\wxs\)
>>> mapserv
>>> QUERY_STRING="map=tomk_workshop.map&service=WMS&version=1.1.1&request=Descr
>>> ibeLayer&layers=rivers" (msautotest\wxs\)
>>> mapserv
>>> QUERY_STRING="map=wfs_filter.map&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeatu
>>> re&TYPENAME=popplace&FILTER=<Filter><PropertyIsGreaterThanOrEqualTo><Proper
>>> tyName>POP_RANGE</PropertyName><Literal>4</Literal></PropertyIsGreaterThanO
>>> rEqualTo></Filter>" (msautotest\wxs\)
>>> Best regards,
>>> Tamas
>>> 2011/3/20 Alan Boudreault<aboudreault at mapgears.com>
>>>  Tamas,
>>>> Could you point me the tests that fail... I will try them on Linux
>>>> first.
>>>> Alan
>>>> On March 19, 2011 01:53:40 pm Tamas Szekeres wrote:
>>>>> Not sure about this, the current version (r11282 in trunk) is also
>>>>> crashing.
>>>>> Best regards,
>>>>> Tamas
>>>>> 2011/3/19 Even Rouault<even.rouault at mines-paris.org>
>>>>>  Le samedi 19 mars 2011 18:19:08, Tamas Szekeres a écrit :
>>>>>>> Hi All,
>>>>>>> I'm experiencing permanent crashes in msautotest on Windows which
>>>>>> prevents
>>>>>>  from the daily builds on http://vbkto.dyndns.org/sdk/ to complete
>>>>>>> successfully.
>>>>>>> While I'm not sure about the exact location of the problem I
>>>>>>> suspect
>>>> it
>>>>  may
>>>>>>  be due to a recent change in the lexer.
>>>>>>> According to my examinations the problem has been introduced
>>>>>>> between
>>>>>> r11192
>>>>>>  and r11196.
>>>>>>> Could someone look into the problem who has better knowledge about
>>>> the
>>>>  changes above?
>>>>>> Tamas, I believe this has been fixed by
>>>>>> http://trac.osgeo.org/mapserver/changeset/11224
>>>>>>  Best regards,
>>>>>>> Tamas
> Daniel Morissette
> http://www.mapgears.com/
> Provider of Professional MapServer Support since 2000
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
URL: http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20110322/f52cb5ca/attachment.html
