[mapserver-dev] RE: 6.0 release plan - RFC45 - Consistent units
	in CLASS-> STYLE
    Tamas Szekeres
    szekerest at gmail.com
    Thu Mar 24 15:50:57 EDT 2011
+1
Tamas
2011/3/24 Lime, Steve D (DNR) <steve.lime at state.mn.us>
> I suppose we should talk on mapserver-dev. ;-) I'm happy to nominate you
> for documentation
> commit access. We like to try to match commits with tickets if non-trivial.
> There is a documentation
> component in trac that Jeff owns that can be used for that.
> One thing to note is that Jeff and Mike Smith started or at least pondered
> staring an "examples"
> effort in Montreal. I could see some of your symbolization examples being
> very useful in that context
> too.
> I'll start with a +1 on granting Havard Tveite commit access for
> documentation.
> Steve
> -----Original Message-----
> From: Havard Tveite [mailto:havard.tveite at umb.no]
> Sent: Thursday, March 24, 2011 11:25 AM
> To: Lime, Steve D (DNR)
> Cc: thomas.bonfort at gmail.com
> Subject: Re: 6.0 release plan - RFC45 - Consistent units in CLASS-> STYLE
> Dear Steve,
> I would be happy to contribute on the documentation
> related to rendering for version 6.  I will, of course,
> have to consult you and Thomas in order to get
> clarifications on what intended behaviour is in some
> cases...
> How do we proceed?  My osgeo user name is havatv.
> I have no experience with committing (I have only
> used SVN to check out).  Is there any documentation
> that can help me avoid making big mistakes when
> committing?
> I have found a book, that I hope can help:
> http://svnbook.red-bean.com/en/1.4/svn-book.pdf
> Is it enough to issue the svn commit command with a
> descriptive message using --message?
> I have had a look at the documentation development
> guide (http://mapserver.org/development/documentation.html),
> which seems reasonably straight forward.
> I have also read RFC 7.1, and have no problems with that.
> Håvard
> On 3/24/2011 3:42 PM, Lime, Steve D (DNR) wrote:
> > We'd be happy to have more documentation committers...
> > From: thomas bonfort [mailto:thomas.bonfort at gmail.com]
> > Sent: Thursday, March 24, 2011 4:46 AM
> > To: Havard Tveite
> > Cc: Lime, Steve D (DNR)
>  STYLE
> > Thanks Havard,
> > For the documentation changes, it would probably be easier if you
> > could commit directly into the mapserver documentation site. I seem to
> > recall that for docs commit access, it is sufficient to post a short
> > message to the -dev list stating which areas you want to work on, and
> > your osgeo userid.
> > ps: good news for rfc45, I've just been on the phone with a customer
> > here in france who will probably be funding the anchorpoint stuff :)
> > On Thu, Mar 24, 2011 at 10:22, Havard Tveite<havard.tveite at umb.no>
>  wrote:
> >> An updated examples.sym (just the explaining text has changed).
> >> Håvard
> >> On 3/24/2011 10:17 AM, Håvard Tveite wrote:
> >>> Very nice!
> >>> How can I help updating the documentation?
> >>> Another thing:
> >>> I looked at the 6beta distribution and found that there
> >>> was a symbol directory.
> >>> I have updated the files in that directory to use the
> >>> Mapserver 6 mechanisms.  You will find the new files
> >>> attached.  I have also included two PNG files that show
> >>> the images produced by the previous map and symbol files
> >>> using Mapserver 5.2 (example-org.png) and my updated
> >>> files using 6beta3 (example.png).
> >>> I have only updated the existing examples, but could
> >>> add other (more advanced) examples if you like.
> >>> Håvard
> >>> On 3/23/2011 4:07 PM, thomas bonfort wrote:
> >>>> Havard,
> >>>> fixed in trunk, please confirm ;)
> >>>> thanks for testing!
> >>>> thomas
> >>>> On Tue, Mar 22, 2011 at 15:27, Havard Tveite<havard.tveite at umb.no>
> >>>> wrote:
> >>>>> Dear Thomas and Steve,
> >>>>> I have now tested quite a bit on 6beta2.
> >>>>> Many improvements!
> >>>>> I have one big concern that I think needs to be addressed
> >>>>> for 6.0:
> >>>>> Units in LAYER->     CLASS->     STYLE
> >>>>> The units used for the different elements of the STYLE now
> >>>>> vary, and I think that will be very confusing to the users.
> >>>>> * WIDTH and SIZE specifies the width/height of the line/symbol
> >>>>>    as the number of pixels/map units at the scale
> >>>>>    1:SYMBOLSCALEDENOM.  I like this!
> >>>>> * GAP uses the same units (that is the gap in pixels/map units
> >>>>>    at the scale 1:SYMBOLSCALEDENOM).  I like this!
> >>>>> * PATTERN uses the WIDTH of the line as the unit, so to get
> >>>>>    the gap as the number of pixels/map units at the scale
> >>>>>    1:SYMBOLSCALEDENOM, you have to multiply the GAP value by
> >>>>>    the value of WIDTH.  I don't like this!
> >>>>> * OFFSET seems to use the same approach as PATTERN when
> >>>>>    "displacing" lines (units relative to line WIDTH).
> >>>>>    For point symbols, it seems to use the same approach as GAP
> >>>>>    (pixels/map units at the scale 1:SYMBOLSCALEDENOM).
> >>>>> My opinion is that the unit used for all the length/width/size
> >>>>> measure elements (GAP, OFFSET, PATTERN, SIZE, WIDTH) of
> >>>>> CLASS->     STYLE should be the number of pixels/map units at the
> >>>>> scale 1:SYMBOLSCALEDENOM (as is currently the case for WIDTH,
> >>>>> SIZE and GAP).  This would mean that the units used for
> >>>>> PATTERN and OFFSET (for lines) would have to be changed.
> >>>>> Håvard
> >>>>> On 11/18/2010 4:13 PM, thomas bonfort wrote:
> >>>>>> Havard,
> >>>>>> rfc45 isn't dead, but the priority now is getting 6.0 out of the
> door,
> >>>>>> so I wouldn't expect those features by then.
> >>>>>> Once 6.0 is out, getting those features in is a matter of time
> and/or
> >>>>>> will and/or funding.
> >>>>>> cheers,
> >>>>>> thomas
> >>>>>> On Tue, Nov 9, 2010 at 16:23, Havard Tveite<havard.tveite at umb.no>
> >>>>>> wrote:
> >>>>>>> Dear Steve and Thomas,
> >>>>>>> I have been extremely busy this summer and autumn, so I
> >>>>>>> have not been able to follow Mapserver developments very
> >>>>>>> closely.  But when I heard about the release plan for 6.0,
> >>>>>>> I thought about RFC45.  There has been some interest
> >>>>>>> during the last years for some of the suggestions there,
> >>>>>>> and I still think that it includes some very good ideas
> >>>>>>> for quality improvements of Mapserver symbol rendering.
> >>>>>>> I have kept track of the progress on Cairo, so I don't know
> >>>>>>> if anything of this has been addressed there.
> >>>>>>> Here are some examples:
> >>>>>>> Stable origin for tile generation + polygon fill symbols:
> >>>>>>>     This would require that for instance the coordinate system
> >>>>>>>     origo be used instead of a local origo when placing tiles
> >>>>>>> Angle options - there has been some demand for compass (the
> >>>>>>>     current vector? default).
> >>>>>>> Possibility to specify symbol origin for precise placement
> >>>>>>>     of symbols.
> >>>>>>> And more.
> >>>>>>> Someone more familiar with the Mapserver code should perhaps
> >>>>>>> go through RFC45 again and check what can be achieved for 6.0.
> >>>>>>> I may have the time in a few weeks to help with specifications.
> >>>>>>> Håvard Tveite
> >>>>>>> On 11/9/2010 8:59 AM, thomas bonfort wrote:
> >>>>>>>> On Mon, Nov 8, 2010 at 18:07, Lime, Steve D (DNR)
> >>>>>>>> <Steve.Lime at state.mn.us>         wrote:
> >>>>>>>>> RFC-50: I think this is out for 6.0 unless those authors are
> still
> >>>>>>>>> around.
> >>>>>>>> yes definitely. I'd like to tackle that one some day, but haven't
> got
> >>>>>>>> the time in the near future
> >>>>>>>>> RFC-52: The changes I’d like to see are relatively minor (from a
> >>>>>>>>> coding
> >>>>>>>>> perspective) and are a return to a single getShape() method in
> >>>>>>>>> MapScript.
> >>>>>>>>> It
> >>>>>>>>> will break 5.6 scripts but is simpler in the long run. I don’t
> know
> >>>>>>>>> that
> >>>>>>>>> an
> >>>>>>>>> RFC is necessary but I will start a ticket and we can go from
> there.
> >>>>>>>>> RFC-54: I think Thomas just needs to merge?
> >>>>>>>> I'm planning to do this before the end of the month. It might slip
> a
> >>>>>>>> bit from the planned 15th november
> >>>>>>>>> RFC-58 – RFC-63: Are all basically complete, perhaps need docs
> >>>>>>>>> though.
> >>>>>>>> RFC58 (kml) still needs a bit of love before being ready
> >>>>>>>>> RFC-64: Needs feedback. This may push us back a week or two
> >>>>>>>>> depending
> >>>>>>>>> on
> >>>>>>>>> feedback. I think 6.0 is the right time to implement though given
> >>>>>>>>> the
> >>>>>>>>> types
> >>>>>>>>> of proposed changes. They are not candidates for minor releases.
> >>>>>>>>> Thanks for pushing on this…
> >>>>>>>>> Steve
> >>>>>>>>> From: mapserver-dev-bounces at lists.osgeo.org
> >>>>>>>>> [mailto:mapserver-dev-bounces at lists.osgeo.org] On Behalf Of
> Tamas
> >>>>>>>>> Szekeres
> >>>>>>>>> Sent: Saturday, November 06, 2010 6:12 PM
> >>>>>>>>> To: mapserver-dev at lists.osgeo.org
> >>>>>>>>> Subject: [mapserver-dev] 6.0 release plan
> >>>>>>>>> Hi All,
> >>>>>>>>> In search of my memory (and my mails) the recent plan of the 6.0
> >>>>>>>>> release
> >>>>>>>>> has
> >>>>>>>>> been scheduled as follows:
> >>>>>>>>> "Plan for a feature freeze on Nov 15th, with a little over 2
> months
> >>>>>>>>> for
> >>>>>>>>> betas, aiming for final release between Jan 15th and 31st"
> >>>>>>>>> How do we stand with the upcoming activities in the light of
> this?
> >>>>>>>>> I can see the following RFCs may be affected or must be
> scheduled:
> >>>>>>>>> RFC-50 (OpenGL)
> >>>>>>>>> RFC-52 (One-pass query processing), we wanted to do some rework
> as
> >>>>>>>>> far
> >>>>>>>>> as
> >>>>>>>>> I
> >>>>>>>>> remember.
> >>>>>>>>> RFC-54 (Rendering overhaul)
> >>>>>>>>> RFC-58 (KML output)
> >>>>>>>>> RFC-62 (Additional WFS GetFeature Output Formats)
> >>>>>>>>> RFC-63 (OpenLayers viewer)
> >>>>>>>>> RFC-64 (Expression parser overhaul)
> >>>>>>>>> Do we have any other plan which will be covered with an RFC soon?
> >>>>>>>>> How
> >>>>>>>>> much
> >>>>>>>>> time the pending efforts will take to be implemented?
> >>>>>>>>> The 6.0 release plan document may also updated with some up to
> date
> >>>>>>>>> information if possible.
> >>>>>>>>> Best regards,
> >>>>>>>>> Tamas
> >>>>>>>>> _______________________________________________
> >>>>>>>>> mapserver-dev mailing list
> >>>>>>>>> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
> >>>>>>> Håvard Tveite
> >>>>>>> Department of Mathematical Sciences and Technology, UMB
> >>>>>>> Drøbakveien 31, POBox 5003, N-1432 Ås, NORWAY
> >>>>>>> Phone: +47 64965483 Fax: +47 64965401 http://www.umb.no/imt/
> >>>>> Håvard Tveite
> >> Håvard Tveite
> Håvard Tveite
URL: http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20110324/3f652c04/attachment-0001.html
