[mapserver-dev] Using backslash in CONNECTION parameter
    Tamas Szekeres
    szekerest at gmail.com
    Sun Mar 27 14:45:23 EDT 2011
I've tried that, but the double backslash is also stripped.
Tamas
2011/3/27 Stephen Woodbridge <woodbri at swoodbridge.com>
> On 3/27/2011 2:36 PM, Tamas Szekeres wrote:
>> Hi All,
>> It seems there have been some changes when parsing the connections
>> strings in 6.0
>> Formerly the following was working:
>> "server=.\MSSQL2008;database=Maps;Integrated Security=true" in the
>> CONNECTION parameter but currently the back slashes are stripped by the
>> lexer.
>> I've checked out the migration guide but didn't find any useful
>> information in this topic.
>> Any workarounds?
> Did you try doubling the backslash? Typically a backslash is an escape
> character within a string it requires \\ to represent a single one.
> Steve L would probably have a better read on if this changed in the recent
> parser changes, but give that a try and see if it helps.
> -Steve W
URL: http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20110327/f93e666e/attachment.html
