[mapserver-dev] CONNECTIONTYPE UNION with STYLEITEM AUTO still
not working in 6.0.0-rc2 (and possible solution)
Tamas Szekeres
szekerest at gmail.com
Mon May 9 11:03:40 EDT 2011
Could you provide the mapfile which doesn't work for you?
Best regards,
Tamas
2011/5/9 Jana Golinowski <jgolinowski at codematix.de>
> Thanks for the fix, applied in SVN-trunk (
>> http://trac.osgeo.org/mapserver/changeset/11664)
>> It's strange that it did not crash on Windows for me and Jeff.
> Great.
> The description on http://www.mapserver.org/trunk/mapfile/union.html says
> something about using PROCESSING to have access on attributes. Is this
> working on Windows only too? For I'm using layer attributes from the
> corresponding source table (PostGIS) for styling, e.g. for COLOR. Looking
> into the debug log I see no items requested for the source layers when the
> union layer is drawn.
> My union layer appears to be empty unless I change those elements, e.g. for
> COLOR 255 0 0 instead [outline]. Maybe I misunderstood the documentation?
> Greetings, Jana.
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
URL: http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20110509/4e6ac875/attachment.html
