[mapserver-dev] Plugin for ESRI File Geodatabase?Support
Paul Ramsey pramsey at opengeo.org
Wed May 18 22:25:32 EDT 2011
The "final" is coming in a couple days (I'm sure more releases will
come after, as I'm still finding bugs in the current beta). The
performance is quite awful at the start-up phase (this seems true
independent of the OGR drivers), so connection caching and fcgi is
going to be required.
I'm working on the OGR drivers as part of a project over the next
month and a bit, so hopefully write access will be improved and I can
help with read performance and feeding info back to the ESRI team, who
are on this project also.
p.
On Wed, May 18, 2011 at 3:08 PM, Smith, Michael ERDC-CRREL-NH
<Michael.Smith at usace.army.mil> wrote:
> It only works (is available) for 32 bit Linux. 64bit support is coming in the
> next release, targeted for mid May (hopefully any day now(tm)).
> See
> http://blogs.esri.com/Dev/blogs/geodatabase/archive/2011/04/13/File-Geodataba
> se-API-_2D00_-4-platform-final-release-set-for-mid_2D00_May.aspx
> Mike
> -----Original Message-----
> From: mapserver-dev-bounces at lists.osgeo.org
> [mailto:mapserver-dev-bounces at lists.osgeo.org] On Behalf Of Even Rouault
> Sent: Wednesday, May 18, 2011 2:55 PM
> To: mapserver-dev at lists.osgeo.org
> Cc: Daniel Morissette
> Subject: Re: [mapserver-dev] Plugin for ESRI File Geodatabase?Support
> Le mercredi 18 mai 2011 17:16:16, Daniel Morissette a écrit :
>> On 11-05-18 11:01 AM, Lime, Steve D (DNR) wrote:
>> > Looks to be Windows specific?
>> Maybe you're right. There is no Linux Makefile in the OGR driver's
>> directory, so it is quite possible that it's been tested only on
>> Windows so far. I'd hope that the code would also work on Linux once
>> the API is available there.
> It does build on Linux. It isn't integrated in the build system for now
> however, so you have to build it as a plugin at hand.
> Something like (adapt the paths of course)
> g++ -Wall -g ogr/ogrsf_frmts/filegdb/*.c* -shared -o ogr_FileGDB.so
> g++ -Iport -
> Igcore -Iogr -Iogr/ogrsf_frmts -Iogr/ogrsf_frmts/filegdb -L. -lgdal -
> I/home/even/filegdb/dist/include -L/home/even/filegdb/dist/lib  -
> I/home/even/filegdb/dist/src/FileGDBEngine/include/FileGDBLinux -lFileGDBAPI
> and then define GDAL_DRIVER_PATH to point to the place where you put
> ogr_FileGDB.so
>> In case you're interested you can browse the source of the OGR driver here:
>> http://trac.osgeo.org/gdal/browser/trunk/gdal/ogr/ogrsf_frmts/filegdb
> mapserver-dev mailing list
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
