[mapserver-dev] Correct usage of SWIG-MapScript-SYMBOL generation
Stephan Holl stephan.holl at intevation.de
Fri May 20 09:11:19 EDT 2011
Hello Mapserver-devs,
we try to add symbols to a SYMBOLSET with Java (1.6.2 on Windows)
MapScript dynamically (with MS 6.0.0-rc2 with MS4W) with this code:
import java.io.IOException;
import java.io.File;
import edu.umn.gis.mapscript.mapObj;
import edu.umn.gis.mapscript.layerObj;
import edu.umn.gis.mapscript.classObj;
import edu.umn.gis.mapscript.styleObj;
import edu.umn.gis.mapscript.symbolObj;
import edu.umn.gis.mapscript.symbolSetObj;
import edu.umn.gis.mapscript.MS_SYMBOL_TYPE;
public class CharTest {
     * Entrypoint for the application.
    public static void main(String[] args) {
       mapObj map = new mapObj("template.map");
       layerObj layer = new layerObj(map);
       classObj co = new classObj(layer);
       symbolSetObj symbolSet = map.getSymbolset();
       symbolObj symbol = symbolSet.getSymbolByName("testname");
       symbol.setType(MS_SYMBOL_TYPE.MS_SYMBOL_TRUETYPE.swigValue());
       symbol.setFont("Arial-alike");
       symbol.setAntialias(1);
       // see
       http://mapserver.org/mapfile/symbology/construction.html#symbols-of-type-truetype
       symbol.setCharacter("");
       symbolSet.save("symbols.sym");
The resulting symbol is
  SYMBOL
    NAME "testname"
    TYPE TRUETYPE
  END
There is no error raising up with the above program, but the result
seems odd. At least FONT and CHARACTER-keywords should be set within
the exported symbolset.
Btw. the keyword SYMBOLSET at the beginning is also missing (see [1]
for a separate issue).
Does anybody can give some advice how to use the
SWIG-based MapScript-API to construct symbolsets correctly.
Best
	Stephan
[1] http://trac.osgeo.org/mapserver/ticket/3885
Stephan Holl <stephan.holl at intevation.de> | Tel.: +49 (0)541-33 508 3663
Intevation GmbH, Neuer Graben 17, 49074 OS  |  AG Osnabrück - HR B 18998
Geschäftsführer:  Frank Koormann, Bernhard Reiter, Dr. Jan-Oliver Wagner
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20110520/3a9abdef/signature.bin
