[mapserver-dev] GEOMTRANSFORM labelpnt location
Brent Fraser
bfraser at geoanalytic.com
Fri May 27 13:55:57 EDT 2011
Håvard,
Based on http://trac.osgeo.org/mapserver/ticket/3335, I think the
intent is to have the point location as documented (center of the
bounding rectangle), so it's a s/w bug. And I've used v6.0 release to
generate the attached png, showing an improved label bbox, but it still
has some X-axis extent problem (see the "Treasure Mountain" label),
although it looks more like a text placement problem.
Best Regards,
Brent Fraser
On 5/27/2011 3:33 AM, Havard Tveite wrote:
> Brent,
> This is a bug. The question is if it is only documentation.
> I suggest you file a ticket.
> The labelpolygon seems to be a bit shifted, also a bug?
> Håvard
> On 5/26/2011 7:59 PM, Brent Fraser wrote:
>> Should we change the documentation on STYLE -> GEOMTRANSFORM ->
>> labelpnt:
>> * labelpnt generates a point with its center at the middle of the
>> bounding rectangle of the text.
>> or is the position generated a bug (or am I using it incorrectly)?
>> Have a look at the blue dot in the attached image.
>> CLASS # Mountain
>> NAME 'Mountain'
>> EXPRESSION ([CONCISCODE]=280)
>> STYLE # ------ Green Cross ------
>> SYMBOL 'CROSS1'
>> SIZE 8
>> WIDTH 0.5
>> COLOR 0 255 0
>> END
>> STYLE # ------ Yellow Circle ------
>> GEOMTRANSFORM (labelpoint([shape]))
>> SYMBOL 'CIRCLE'
>> SIZE 5
>> OUTLINECOLOR 255 255 0
>> END
>> LABEL
>> STYLE # ------ Red Box ------
>> GEOMTRANSFORM labelpoly
>> OUTLINECOLOR 255 0 0
>> END #
>> STYLE # ------ Blue Dot ------ position OK?
>> SYMBOL 'CIRCLE'
>> SIZE 2
>> COLOR 0 0 255
>> END #
>> FONT "trebuc"
>> TYPE TRUETYPE
>> POSITION CC
>> ALIGN CENTER
>> WRAP ' '
>> SIZE 6
>> BUFFER 1
>> COLOR 0 0 0
>> ANGLE 0
>> PARTIALS FALSE
>> ANTIALIAS TRUE
>> #MINDISTANCE 250
>> #MINFEATURESIZE 10
>> END
>> END
>> Best Regards,
>> Brent Fraser
Type: image/png
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20110527/70a73377/label_styles-0001.png
