[mapserver-dev] problem with mapscript and outputformat
Alan Boudreault
aboudreault at mapgears.com
Tue Nov 29 10:11:29 EST 2011
You are right... I think you can't access those outputformat object. The
only way I see is to use map->selectOutputFormat() then,
map->outputformat, but you need to know all outputFormat name.
Alan
On 11-11-28 03:33 PM, Ing. Romanuel Ramon Antunez wrote:
> Hello community, I have a question, I'm working with php-
> mapscript and I'm loading a .map that has declared
> several OutputFormat, however with mapscript only
> I access the first to appear, how I can access the
> others?
> regards
>> mapserver-dev mailing list
>> mapserver-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
> Fin a la injusticia, LIBERTAD AHORA A NUESTROS CINCO COMPATRIOTAS QUE SE ENCUENTRAN INJUSTAMENTE EN PRISIONES DE LOS EEUU!
> http://www.antiterroristas.cu
> http://justiciaparaloscinco.wordpress.com
