[mapserver-dev] Re: Problem with projectionObj
Daniel Morissette dmorissette at mapgears.com
Tue Oct 4 11:21:42 EDT 2011
On 11-10-04 02:54 AM, Itacasoft wrote:
> More information about this bug. Putting DEBUG 5 does create a log file,
> but always empty very strange. I thought about a permission problem, but
> setting the application pool identity to Local System did not resolve.
> Tried IIS 6.0 + Windows XP Pro, and here it works! So, may it be a IIS
> configuration issue?
Could it be that you have multiple values of MS_ERRORFILE set in
environment variables and in your mapfile(s)?
For instance, if you set MS_ERRORFILE in an environment variable, then
this value will be used for logging activity until the mapfile is
parsed, and then after parsing the value set via CONFIG MSERRORFILE will
override the previous value, and then logging may go to a different
file, potentially leaving the first log file empty.
It is also possible to get an empty log file if the mapserv process
crashes before the output buffer is flushed.
Daniel Morissette
http://www.mapgears.com/
Provider of Professional MapServer Support since 2000
