R: [mapserver-dev] Re: Problem with projectionObj
Tamas Szekeres
szekerest at gmail.com
Tue Oct 4 14:17:24 EDT 2011
How did you obtain the binaries? I'd be curious to know whether the binaries
from http://www.gisinternals.com/sdk/ would work or not?
You might want to try using the MSVC2010 versions x86 or x64 depending on
your OS platform/architecture.
Best regards,
Tamas
2011/10/4 GMail <itacasoft at gmail.com>
> Yes, I think this is a permission issue, as most of IIS related problems
> I also made another try:
> I ported the previous code to a simple, simple console application. Well,
> while the ASP.NET version fails both with IIS and with the VS2010 web
> debugger, the console program works smoothly, producing all 10 image maps
> and even filling the MS_ERRORFILE file with lots of stuff. Tried also with
> a
> remote Windows 2008 Server, even there the web version does not work.
> Here is the code:
> ///BEGIN
> using System;
> using System.Collections.Generic;
> using System.Linq;
> using System.Text;
> using OSGeo.MapServer;
> using System.IO;
> namespace GenerateMap
> class Program
> const string MERCATORE_PROJ4 = "+proj=merc +a=6378137 +b=6378137
> +lat_ts=0.0 +lon_0=0.0 +x_0=0.0 +y_0=0 +k=1.0 +units=m +nadgrids=@null
> +wktext +no_defs";
> const string WGS84_PROJ4 = "+proj=longlat +ellps=WGS84 +datum=WGS84
> +no_defs";
> static void DrawAMap(int index)
> bool exists;
> string filename =
> @"C:\usr\lavoro\progetti\SilverlightMapServer\GisData\Demo\Terni\terni.map";
> mapObj map = null;
> try
> map = new mapObj(filename);
> catch (Exception ex)
> string msg = ex.Message;
> Console.WriteLine(msg);
> int w = 800;
> map.width = w;
> int h = 600;
> map.height = h;
> rectObj bbox = new rectObj(12.6198865008904, 42.5498576637217,
> 12.6710248924462, 42.5784118606357, 0);
> map.setProjection(MERCATORE_PROJ4);
> projectionObj projMercatore = new
> projectionObj(MERCATORE_PROJ4);
> projectionObj projWGS84 = new projectionObj(WGS84_PROJ4);
> try
> ///HERE first time OK, second time hangs
> bbox.project(projWGS84, projMercatore);
> //map.extent = bbox;
> map.setExtent(bbox.minx, bbox.miny, bbox.maxx, bbox.maxy);
> imageObj image = map.draw();
> MemoryStream memstrm = new MemoryStream(image.getBytes());
> memstrm.Position = 0;
> FileStream outStream = File.OpenWrite("mapimage" +
> index.ToString() + ".png");
> memstrm.WriteTo(outStream);
> outStream.Flush();
> outStream.Close();
> bbox.Dispose();
> projWGS84.Dispose();
> projMercatore.Dispose();
> image.Dispose();
> map.Dispose();
> static void Main(string[] args)
> for (int i = 0; i < 10; i++)
> DrawAMap(i);
> ///END
> It seems there is a big problem with MapScript 6.0.1 (from MS4W) + ASP.NET+
> IIS 7.0. Anybody has the same environment? Experiencing problems?
> -----Messaggio originale-----
> Da: mapserver-dev-bounces at lists.osgeo.org
> [mailto:mapserver-dev-bounces at lists.osgeo.org] Per conto di Daniel
> Morissette
> Inviato: martedì 4 ottobre 2011 17:42
> A: mapserver-dev at lists.osgeo.org
> Oggetto: Re: R: [mapserver-dev] Re: Problem with projectionObj
> On 11-10-04 11:37 AM, GMail wrote:
> > Thanks for your answer.
> > The first explanation is not possible, because the same code works for
> IIS
> > 6.0, while it does not on IIS 7.0.
> > The second is something I do not understand: using MapScript and ASP.NETI
> > do not have a process "mapserv" that can crash ... but I understand that
> if
> > the IIS handler process crashes or hangs in some way, it may block the
> > output buffer, and this is likely. But this does not explain why this
> > happens only on IIS 7.0 and not on IIS 6.0. How can I have more log
> > information?
> Maybe a permission issue? Sorry, I'm no IIS expert, just guessing...
> Maybe try using MS_ERRORFILE "windowsdebug" with tools such as DebugView
> and see if that makes any difference?
> http://mapserver.org/optimization/debugging.html#step-1-set-the-ms-errorfile
> -variable
> Daniel Morissette
> http://www.mapgears.com/
> Provider of Professional MapServer Support since 2000
> mapserver-dev mailing list
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
URL: http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20111004/8f80bce3/attachment-0001.html
