[mapserver-dev] mapscript OWS request GET/POST
Fabian Schindler
fabian.schindler at eox.at
Wed Oct 5 09:45:48 EDT 2011
Hi devs,
I have a petition regarding HTTP request methods.
AFAIK, previously all OWSes (which are also supporting POST) were
treating requests as GET requests if the request method was not
explicitly set to MS_POST_REQUEST.
With r12550 we committed a patch to unify OWS requests. We were
explicitly checking if the request method was MS_GET_REQUEST or
MS_POST_REQUEST.
It worked well with the msautotests but it broke the mapscript
implementation unless the request method was explicitly set to
MS_GET_REQUEST. Apparently the request method in the `OWSRequest` object
is initially set to an invalid identifier ('-1').
Currently the code is not backwards compatible and is breaking old code
relying on mapscript, as in our case.
Now my question/proposal:
Should I change the handling of request methods back to "everything that
is not a POST request is a GET request."?
I would prefer that the request method in the `OWSRequest` defaults to
MS_GET_REQUEST, since this is normally the default request method.
For the second version I'd add an additional check for any invalid
request methods.
Thanks,
Fabian
