[mapserver-dev] Polygon Background Color
Conor McCauley
conor.mccauley at mapflow.com
Thu Oct 13 10:31:21 EDT 2011
Hi Folks,
I'm having a bit of trouble setting the background color on my maps which
render polygon shapes based on Oracle spatial data. It always seems to
render transparent.
I've tried setting the IMAGECOLOR on the MAP element, the BACKGROUNDCOLOR in
the CLASS elements, but nothing seems to work. I've tried everything it
seems, so any help or advice would be much appreciated.
Kind Regards,
Conor.
Here is a sample map file:
# Start of map file
MAP
DEBUG 5
CONFIG "CPL_DEBUG" "ON"
CONFIG "MS_ERRORFILE" "/tmp/mapserver.log"
NAME BGS
STATUS ON
SIZE 600 600
UNITS METERS
IMAGETYPE PNG
IMAGECOLOR 191 191 255
PROJECTION
"init=epsg:3857"
END
OUTPUTFORMAT
NAME png
DRIVER "GD/PNG"
MIMETYPE "image/png"
IMAGEMODE RGBA
EXTENSION "png"
FORMATOPTION "INTERLACE=ON"
END
WEB
METADATA
OWS_ENABLE_REQUEST "*"
END
END
# --- BGS DISSOLUTION ---
LAYER
DEBUG 5
NAME bgs_dissolution_uk_ora
TYPE POLYGON
STATUS ON
CONNECTION 'GEOSUK/Geosuk1ns at 192.168.160.108/geosuat.mapflow.local'
CONNECTIONTYPE oraclespatial
DATA "geom from (select class, geom from FS_SOLUBLEROCKS_UK) USING SRID
81989"
PROCESSING "CLOSE_CONNECTION=DEFER"
OPACITY 50
PROJECTION
"init=epsg:27700"
END
CLASSITEM "CLASS"
CLASS
EXPRESSION "E"
COLOR 255 0 0
DEBUG on
OUTLINECOLOR 0 0 0
END
CLASS
EXPRESSION "D"
COLOR 255 153 0
DEBUG on
OUTLINECOLOR 0 0 0
END
CLASS
EXPRESSION "C"
COLOR 0 255 0
DEBUG on
OUTLINECOLOR 0 0 0
END
CLASS
EXPRESSION "B"
COLOR 0 0 255
DEBUG on
OUTLINECOLOR 0 0 0
END
CLASS
EXPRESSION "A"
COLOR 0 0 0
DEBUG on
OUTLINECOLOR 0 0 0
END
END
# --- BGS COLLAPSE --
LAYER
# DEBUG 5
NAME bgs_collapse_uk_ora
TYPE POLYGON
STATUS ON
DATA "geom from (select class, geom from FS_COLLAPSIBLEDEPOSITS_UK)
USING SRID 81989"
OPACITY 50
PROJECTION
"init=epsg:27700"
END
CLASSITEM "CLASS"
CLASS
EXPRESSION "E"
COLOR 255 0 0
# DEBUG on
OUTLINECOLOR 0 0 0
END
CLASS
EXPRESSION "D"
COLOR 255 153 0
# DEBUG on
OUTLINECOLOR 0 0 0
END
CLASS
EXPRESSION "C"
COLOR 0 255 0
# DEBUG on
OUTLINECOLOR 0 0 0
END
CLASS
EXPRESSION "B"
COLOR 0 0 255
# DEBUG on
OUTLINECOLOR 0 0 0
END
CLASS
EXPRESSION "A"
COLOR 0 0 0
# DEBUG on
OUTLINECOLOR 0 0 0
END
END
# --- BGS COMPRESS --
LAYER
# DEBUG 5
NAME bgs_compress_uk_ora
TYPE POLYGON
STATUS ON
DATA "geom from (select class, geom from FS_COMPRESSIBLEGROUND_UK) USING
SRID 81989"
OPACITY 50
PROJECTION
"init=epsg:27700"
END
CLASSITEM "CLASS"
CLASS
EXPRESSION "E"
COLOR 255 0 0
# DEBUG on
OUTLINECOLOR 0 0 0
END
CLASS
EXPRESSION "D"
COLOR 255 153 0
# DEBUG on
OUTLINECOLOR 0 0 0
END
CLASS
EXPRESSION "C"
COLOR 0 255 0
# DEBUG on
OUTLINECOLOR 0 0 0
END
CLASS
EXPRESSION "B"
COLOR 0 0 255
# DEBUG on
OUTLINECOLOR 0 0 0
END
CLASS
EXPRESSION "A"
COLOR 0 0 0
# DEBUG on
OUTLINECOLOR 0 0 0
END
END
# --- BGS RUNNING SANDS --
LAYER
# DEBUG 5
NAME bgs_runningsands_uk_ora
TYPE POLYGON
STATUS ON
DATA "geom from (select class, geom from FS_RUNNINGSAND_UK) USING SRID
81989"
OPACITY 50
PROJECTION
"init=epsg:27700"
END
CLASSITEM "CLASS"
CLASS
EXPRESSION "E"
COLOR 255 0 0
# DEBUG on
OUTLINECOLOR 0 0 0
END
CLASS
EXPRESSION "D"
COLOR 255 153 0
# DEBUG on
OUTLINECOLOR 0 0 0
END
CLASS
EXPRESSION "C"
COLOR 0 255 0
# DEBUG on
OUTLINECOLOR 0 0 0
END
CLASS
EXPRESSION "B"
COLOR 0 0 255
# DEBUG on
OUTLINECOLOR 0 0 0
END
CLASS
EXPRESSION "A"
COLOR 0 0 0
# DEBUG on
OUTLINECOLOR 0 0 0
END
END
# --- BGS SHRINK SWELL --
LAYER
# DEBUG 5
NAME bgs_shrinkswell_uk_ora
TYPE POLYGON
STATUS ON
DATA "geom from (select class, geom from FS_SHRINKSWELL_UK) USING SRID
81989"
OPACITY 50
PROJECTION
"init=epsg:27700"
END
CLASSITEM "CLASS"
CLASS
EXPRESSION "E"
COLOR 255 0 0
# DEBUG on
OUTLINECOLOR 0 0 0
END
CLASS
EXPRESSION "D"
COLOR 255 153 0
# DEBUG on
OUTLINECOLOR 0 0 0
END
CLASS
EXPRESSION "C"
COLOR 0 255 0
# DEBUG on
OUTLINECOLOR 0 0 0
END
CLASS
EXPRESSION "B"
COLOR 0 0 255
# DEBUG on
OUTLINECOLOR 0 0 0
END
CLASS
EXPRESSION "A"
COLOR 0 0 0
# DEBUG on
OUTLINECOLOR 0 0 0
END
END
# --- BGS LANDSLIDE --
LAYER
# DEBUG 5
NAME bgs_landslide_uk_ora
TYPE POLYGON
STATUS ON
DATA "geom from (select class, geom from FS_LANDSLIDES_UK) USING SRID
81989"
OPACITY 50
PROJECTION
"init=epsg:27700"
END
CLASSITEM "CLASS"
CLASS
EXPRESSION "E"
COLOR 255 0 0
# DEBUG on
OUTLINECOLOR 0 0 0
END
CLASS
EXPRESSION "D"
COLOR 255 153 0
# DEBUG on
OUTLINECOLOR 0 0 0
END
CLASS
EXPRESSION "C"
COLOR 0 255 0
# DEBUG on
OUTLINECOLOR 0 0 0
END
CLASS
EXPRESSION "B"
COLOR 0 0 255
# DEBUG on
OUTLINECOLOR 0 0 0
END
CLASS
EXPRESSION "A"
COLOR 0 0 0
# DEBUG on
OUTLINECOLOR 0 0 0
END
END
END # Map File
-end-
This email and its content/attachments are covered by Mapflow's email disclaimer, please see www.mapflow.com/disclaimer
URL: http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20111013/5ba66abb/attachment.html
