[mapserver-dev] grid and python mapscript - missing ?
Steve Lime sdlime at gmail.com
Wed Oct 19 14:39:58 EDT 2011
Sorry for the delayed response, I didn't see any other responses...
You're correct. I see in mapserver.h that the grid object is hidden
from SWIG. I think that's because of the way a graticuleObj manifests
itself in a layer. It's only there (via layer->layerinfo) if GRID is
present at the time the mapfile is processed. Hmmm...
I'm wondering then if you work through the
layer->updateFromString(gridText) where gridText contains the
appropriate mapfile snippet. Is that sufficient?
There may be other alternatives such as exposing the graticuleObj to
SWIG and then adding a method like layer->getGrid().
Steve
On Sat, Oct 8, 2011 at 4:12 AM, Jachym Cepicky <jachym.cepicky at gmail.com> wrote:
> Hi,
> is there a way, how to define GRID with help of Python mapscript? I have a
> feeling, that it is missing in the swig interface.
> Thanks
> Jachym
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
