[mapserver-dev] Problem deploying C# mapscript on Windows 2008
Tamas Szekeres szekerest at gmail.com
Sun Oct 23 05:10:52 EDT 2011
Fabrizio,
Did you install all the dependent dll-s, like mapscript.dll, libmap.dll etc
into the /bin directory or such folder which is available in the PATH
environment?
You may use the process monitoring tool (like
http://technet.microsoft.com/en-us/sysinternals/bb896645) to make sure which
dll could not be loaded at run time.
Best regards,
Tamas
2011/10/23 GMail <itacasoft at gmail.com>
> Hello, I'm having problems installing my ASP.NET 3.5 application on a
> Windows 2008 Server R2. The asp.net page complains it cannot load
> mapscript_csharp.dll, while in my development environment (7 Pro) it works
> smootly.
> These are the  steps I took:
> - published the web application and uploaded it on the server
> (mapscript_csharp.dll is installed on the \bin folder)
> - I used the release from release-1500-gdal-1-8-1-mapserver-6-0-1,
> installed
> on a directory that I included in the path.
> - installed VS2008 C++ redist;
> Nothing works. What can it be?
> Thanks,
> Fabrizio
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
URL: http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20111023/43b2cd5b/attachment.html
