[mapserver-dev] RE: [mapserver-users] PHP mapscript-how toaddlabel style
Alan Boudreault aboudreault at mapgears.com
Tue Oct 25 11:09:23 EDT 2011
Ok, you are probably using an old C# binding. You will have to use the
development package and rebuild your binding.
release-1600-gdal-1-8-mapserver-6-0 is a stable package. I think this
package should work: release-1600-gdal-mapserver
Alan
On 11-10-25 11:06 AM, Andrew Monteiro wrote:
> Hi Alan,
> Unfortunately there is no "insertStyle()" method on the labelObj class
> in C#.
> I can confirm that it is present for a classObj.
> Cheers,
> Andy
> -----Original Message-----
> From: mapserver-dev-bounces at lists.osgeo.org
> [mailto:mapserver-dev-bounces at lists.osgeo.org] On Behalf Of Alan
> Boudreault
> Sent: October 25, 2011 10:46 AM
> To: mapserver-dev at lists.osgeo.org
> Subject: Re: [mapserver-dev] RE: [mapserver-users] PHP mapscript-how
> toaddlabel style
> As mentionned in my previous mail, In all SWIG Bindings (this includes
> C#), you have to use the following label method:
> label.insertStyle(styleObj(null))
> Thanks,
> Alan
> On 11-10-25 10:46 AM, Andrew Monteiro wrote:
>> Hi Alan,
>> "new styleObj()" is not permitted. I could use 'new styleObj(null)'.
>> However that would give me a styleobj instance that is not associated
>> with anything. I'm trying to associate a style with a label, as per
> the
>> new organization.
>> There is no way to assign a style object you create to anything except
>> by using the constructor's classObj parameter. i.e. if I was to do
> "new
>> styleObj(null)" there is no way after that to associate that styleObj
>> instance with a class instance or a label instance.
>> Hence, we need to add another constructor to the style object along
> the
>> lines of "new styleObj(someLabelObj)" or have some method that allows
> a
>> style object to be associated with a class instance and/or a label
>> instance.
>> I'm not sure if you want to do it outside of the constructor in case
> you
>> end up with a styleObj instance associated with multiple class/labels.
>> I'm not sure if that's a good thing for the internals, or a good thing
>> programmatically either.
>> Hope that make sense.
>> Cheers!
>> Andrew
>> Boudreault
>> Sent: October 25, 2011 8:39 AM
>> Subject: Re: [mapserver-dev] RE: [mapserver-users] PHP mapscript -how
>> toaddlabel style
>> Andrew,
>> Are you saying that "new styleObj()" is not allowed? I haven't
> modified
>> that part of swig... and checking the code parent_class==NULL is
>> supposed to be allowed.
>> Alan
>> On 11-10-24 12:04 PM, Andrew Monteiro wrote:
>>> Looks like the C# bindings did not get updated.
>>> I downloaded the latest daily build binaries from
>>> http://vbkto.dyndns.org/sdk/.
>>> MSVC2010 (Win32)
>>> finished at 2011.10.24. 8:12:20,18
>>> r12689, r23275
>>> I am using c# .Net4, and the only option I have for creating a Style
>>> object is
>>> new styleObj(classObj parent_class)
>>> Cheers,
>>> Andy
>>> [mailto:mapserver-dev-bounces at lists.osgeo.org] On Behalf Of Andrew
>>> Monteiro
>>> Sent: October 18, 2011 10:54 AM
>>> Subject: RE: [mapserver-dev] RE: [mapserver-users] PHP mapscript -
> how
>>> toaddlabel style
>>> I'll try to get to the C# test later this week. I'm unfortunately out
>> of
>>> the office most of today and tomorrow.
>>> Andy
>>> Boudreault
>>> Sent: October 17, 2011 4:56 PM
> how
>>> toadd label style
>>> I have committed a patch in trunk. Feel free to test. I have also
>> fixed
>>> the SWIG part... but only tested in python. If anyone could test it
> in
>>> java,perl or csharp, it would be nice.
>>> Note: to insert a style... it's different for php vs swig bindings.
>> Just
>>> use the same thing you would have used for the classObj:
>>> - PHP: new styleObj(myLabel)
>>> - SWIG: label.insertStyle(styleObj())
>>> Thanks,
>>> Alan
>>> On 11-10-17 01:15 PM, Alan Boudreault wrote:
>>>> I'm currently looking at this issue.
>>>> Alan
>>>> On 11-10-16 09:56 PM, Ian Walberg wrote:
>>>>> Folks,
>>>>> Is this something we can help add?
>>>>> Regards
>>>>> Ian
>>>>> From: mapserver-users-bounces at lists.osgeo.org
>>>>> [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Ian
>>>>> Walberg
>>>>> Sent: Monday, October 03, 2011 12:26 PM
>>>>> To: Steve Lime
>>>>> Cc: mapserver-users at lists.osgeo.org
>>>>> Subject: RE: [mapserver-users] PHP mapscript - how to add label
>> style
>>>>> http://trac.osgeo.org/mapserver/ticket/4038
>>>>> From: Steve Lime [mailto:sdlime at gmail.com]
>>>>> Sent: Wednesday, September 28, 2011 8:30 PM
>>>>> To: Ian Walberg
>>>>> Subject: Re: [mapserver-users] PHP mapscript - how to add label
>> style
>>>>> I'm guessing this is a bug, could you quick file a ticket and we'll
>>> make
>>>>> sure this is addressed in 6.0.2?
>>>>> Steve
>>>>> On Tue, Sep 27, 2011 at 10:21 AM, Ian Walberg
>>>>> <ian.walberg at airborne.aero>    wrote:
>>>>>> Hello,
>>>>>> I am sure it is staring me in the face but we cannot see how to
> add
>>> a
>>>>>> style to a label (Mapserver 6.x) using PHP mapscript.
>>>>>> Works fine via map file and we see the open issue with the save
> not
>>>>>> including the geotransform line.
>>>>>> What are we missing?
>>>>>> Thanks
>>>>>> Ian
>>>>>> _______________________________________________
>>>>>> mapserver-users mailing list
>>>>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
>>>>> mapserver-dev mailing list
>>>>> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
