[mapserver-dev] mod_geocache build problems
thomas bonfort thomas.bonfort at gmail.com
Wed Sep 7 07:29:50 EDT 2011
patch committed. we require pixman >= 0.13.2
On Wed, Sep 7, 2011 at 11:51, thomas bonfort <thomas.bonfort at gmail.com> wrote:
> Hi Steve,
> a couple of remarks:
> - I've copied the mod-geocache repository into the mapcache folder in
> mapserver's trunk. all new development will go there from now on.
> - --with-cairo isn't used anymore, replaced by --with-pixman (which
> was a cairo dependency)
> - you are using a very old version of pixman, try updating it , or
> configure with --without-pixman (not recommended performance wise).
> I'll update the autoconf script to require a more recent version.
> thomas
> On Tue, Sep 6, 2011 at 22:26, Stephen Woodbridge
> <woodbri at swoodbridge.com> wrote:
>> Hi Thomas,
>> I just updated svn and tried to build and ran into a couple of problems:
>> autoconf
>> ./configure --with-cairo=no
>> make
>> And I got an error about sqlite. Sqlite is install on the system, but was
>> not requested. Retried with:
>> ./configure --with-cairo=no --with-sqlite=no
>> make
>> And I got errors about not having pixman so I installed that
>> woodbri at mappy:~/work/mod-geocache$ apt-show-versions | grep pixman
>> libpixman-1-0/lenny uptodate 0.10.0-2
>> libpixman-1-dev/lenny uptodate 0.10.0-2
>> woodbri at mappy:~/work/mod-geocache$ ./config.status -V
>> config.status
>> configured by ./configure, generated by GNU Autoconf 2.61,
>>  with options "'--with-cairo=no' '--with-sqlite=no'"
>> make
>> gcc -o geocache_seed -DLINUX=2 -D_REENTRANT -D_GNU_SOURCE -pthread -O2 -Wall
>> -fPIC -DHAVE_SYMLINK -DNDEBUG -I../include -DTHREADED_MPM=0
>> -I/usr/local/include/gdal -I/usr/include -I/usr/include/apr-1.0
>> -I/usr/include/apr-1.0 -I/usr/include/postgresql -I/usr/include/mysql
>> -DUSE_PCRE -DUSE_OGR -DUSE_GEOS -DUSE_PIXMAN -I/usr/include/pixman-1
>> geocache_seed.c ./.libs/cache_memcache.o ./.libs/imageio_jpeg.o
>> ./.libs/tileset.o ./.libs/service_kml.o ./.libs/configuration_json.o
>> ./.libs/service_tms.o ./.libs/service_wms.o ./.libs/service_demo.o
>> ./.libs/source_wms.o ./.libs/imageio_png.o ./.libs/source.o
>> ./.libs/imageio_mixed.o ./.libs/service_wmts.o ./.libs/core.o
>> ./.libs/source_gdal.o ./.libs/ezxml.o ./.libs/grid.o ./.libs/cJSON.o
>> ./.libs/axisorder.o ./.libs/http.o ./.libs/imageio.o ./.libs/lock.o
>> ./.libs/cache_disk.o ./.libs/dimension.o ./.libs/services.o
>> ./.libs/service_ve.o ./.libs/buffer.o ./.libs/util.o
>> ./.libs/configuration_xml.o ./.libs/image.o ./.libs/configuration.o
>> ./.libs/image_error.o ./.libs/cache_sqlite.o  /usr/lib/libaprutil-1.so
>> -lldap -llber /usr/lib/libdb-4.6.so /usr/lib/libmysqlclient_r.so -lm
>> /usr/lib/libapr-1.so -luuid -lpcre -lpixman-1 -L/usr/local/lib
>> /usr/local/lib/libgdal.so -L/usr/lib /usr/lib/libsqlite3.so
>> /usr/lib/libodbc.so /usr/lib/libodbcinst.so /usr/lib/libltdl.so
>> /usr/lib/libexpat.so -lxerces-c /usr/local/lib/libNCSEcw.so
>> /usr/local/lib/libNCSCnet.so /usr/local/lib/libNCSUtil.so
>> /usr/lib/libjasper.so -lmfhdf -ldf -logdi /usr/lib/libgif.so
>> /usr/lib/libjpeg.so -lpng -lnetcdf -lpq -lrt -ldl /usr/lib/libcurl.so
>> -L/u/software/Geo_DSDK-7.0.0.2167/3rd-party/lib/Release
>> -L/u/software/Geo_DSDK-7.0.0.2167/lib/Release -lltidsdk -L/usr/lib/mysql
>> /usr/lib/libmysqlclient.so -lpthread -lcrypt -lnsl -lz -lgeos_c
>> ./.libs/image.o: In function `geocache_image_copy_resampled_bilinear':
>> image.c:(.text+0x188): undefined reference to
>> `pixman_transform_init_translate'
>> image.c:(.text+0x1c4): undefined reference to `pixman_transform_scale'
>> ./.libs/image.o: In function `geocache_image_copy_resampled_nearest':
>> image.c:(.text+0x2e8): undefined reference to
>> image.c:(.text+0x324): undefined reference to `pixman_transform_scale'
>> ./.libs/image.o: In function `geocache_image_merge':
>> image.c:(.text+0x4a7): undefined reference to
>> collect2: ld returned 1 exit status
>> make[1]: *** [geocache_seed] Error 1
>> make[1]: Leaving directory `/u/work/mod-geocache/src'
>> make: *** [all] Error 2
>> mapserver-dev mailing list
>> mapserver-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
