[mapserver-dev] Runtime Substitution bug
Nicolas BOUTET
nicolas.boutet at geosys.com
Thu Sep 15 12:07:15 EDT 2011
Hello,
I'm using MapServer 6.0.1 in conjunction with GDAL 1.8 (Tamas binaries) with
IIS 7.5, and I get an issue while using runtime substitution.
I have a LAYER where the data source if defined like this :
CONNECTIONTYPE OGR
CONNECTION
"OCI:./.. at gti5500"
DATA "SELECT idblock, entitiesMbr
FROM block
WHERE idblock = %idBlock% "
Please note that there is a space character at the end of the SQL statement,
after the variable to substitute.
All is working fine while the space is still here.
If I remove it, I get an Error 500 from the Server and the Windows
Application logs register an error in the MSVCR100.dll module.
Of course, the layer contains also a validation block like this:
VALIDATION
idblock
'^[0-9]{1,6}$'
END
It seems that this is a bug in variable substitution. Can you confirm this?
Have you already observe this kind of issue?
Regards
Nicolas
URL: http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20110915/ab34d527/attachment.html
