[mapserver-dev] Parsing error with PostGIS DATA statement
Jan Hartmann
j.l.h.hartmann at uva.nl
Sat Sep 17 09:21:38 EDT 2011
This is such a weird error that I ask for confirmation before submitting
a bug. The following declaration of a PostGIS connection does *not* work:
connectiontype postgis
connection "..."
data " rd_bnd from (
select gid,bladnr,rd_bnd from tmk.bladgrenzen
) as foo using unique gid using srid=28992
while the following works fine:
connection "..."
Don't try to spot the difference: the mailer automatically changes tabs
into blanks.
If there are tabs (or newlines) around the first variable in the data
clause, the query fails: the database is queried with the tab or newline
added to the variable name and returns the error "variable not found".
In the subselect you can put as many tabs,newlines or other whitespace
as you like.
If this is really an error (perhaps I am dizzy from looking for half an
afternoon at this data statement), there must be more cases where the
parser doesn't get it right. Can anyone confirm?
Jan
URL: http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20110917/43d40afb/attachment.html
