[mapserver-dev] mapcache WMTS: offset on some zoom levels
Mathias Walker
mwa at sourcepole.ch
Thu Sep 29 05:48:44 EDT 2011
Hello
While setting up a mapcache WMTS for EPSG:21781 I noticed that the tile data
on some zoom levels is offset to the reference data when loading it with
OpenLayers. If I load the same layer as mapcache TMS all zoom levels are
correctly aligned.
Am I missing some configuration options or are there some issues in the WMTS
calculation?
OpenLayers uses the same extent and resolutions as the mapcache config.
The following zoom levels are offset for WMTS in my setup:
(0 - 6 unknown) 7, 8, 9, 10, 12, 13, 14, 15, 17, 19, 24
Here are my settings:
mapcache.xml grid:
<grid name="CH1903">
<metadata>
<title>CH1903 / LV03</title>
</metadata>
<srs>EPSG:21781</srs>
<units>m</units>
<extent>420000,30000,900000,350000</extent>
<resolutions>4000,3750,3500,3250,3000,2750,2500,2250,2000,1750,1500,1250,1000,750,650,500,250,100,50,20,10,5,2.5,2,1.5,1,0.5</resolutions>
<size>256 256</size>
</grid>
OpenLayers:
var options = {
controls: [],
projection: new OpenLayers.Projection("EPSG:21781"),
units: "m",
maxExtent: new OpenLayers.Bounds.fromArray([420000,30000,900000,350000]),
restrictedExtent: new
resolutions:
[4000,3750,3500,3250,3000,2750,2500,2250,2000,1750,1500,1250,1000,750,650,500,250,100,50,20,10,5,2.5,2,1.5,1,0.5],
allOverlays: false
var map = new OpenLayers.Map("map", options);
map.addLayer( new OpenLayers.Layer.WMTS({
url: "http://???.sourcepole.ch/mapcache/wmts/",
layer: 'bezirksgrenzen',
matrixSet: 'CH1903',
format: 'image/png',
style: 'default',
buffer:0,
isBaseLayer:false,
maxExtent: new OpenLayers.Bounds(420000,30000,900000,350000)
map.addLayer( new OpenLayers.Layer.TMS(
"Bezirksgrenzen TMS",
"http://???.sourcepole.ch/mapcache/tms",
layername: "bezirksgrenzen",
type: "png",
isBaseLayer: false,
buffer: 0,
visibility: true
Best regards
Mathias Walker
Sourcepole - Linux & Open Source Solutions
Churerstrasse 22, 8808 Pfäffikon SZ, Switzerland
Tel: 044 440 77 11 Fax: 044 440 77 12
mwa at sourcepole.ch http://www.sourcepole.ch
