[mapserver-dev] RFC84 call for vote: migrate from svn/trac to
	git/github
    thomas bonfort
    thomas.bonfort at gmail.com
    Mon Apr  2 13:23:11 EDT 2012
I don't have an easy answer for those points.
On Mon, Apr 2, 2012 at 18:45, Lime, Steve D (DNR)
<Steve.Lime at state.mn.us> wrote:
> Regarding the inconveniences:
>  - How to handle private security tickets? In all likelihood we will need this capability. Fall back to OSGeo trac instance until a public ticket can be created?
That could be an option, although I don't know if we can freeze all
but actual "seccurity - private
" component in trac. Other options boil down to hosting a private
issue tracker somewhere else. I doubt github will some day give the
option to mark a bug private in a public repository, otherwise anyone
could start using their issue tracker privately.
>  - Image attachments. Can/should we specify a standard approach, a mapserver-specific collection point?
I have no long term solution for this one, as image hosts tend to die
or delete images after a period of inactivity. For the active lifetime
of the bugreport, I think there are many online hosters that will do.
> On the githup side how does my github user (sdlime) get associated with "Steve Lime" in the repository?
The match is done through your email address, which I got from our
COMMITERS file or manually looked up for the doc contributors that
aren't listed in that file. Note for Alan and maybe others: if you are
signed up to github with a different email address than the one in
COMMITERS, you can add multiple email adresses to your github account.
This is actually only usefull if you want your userid to be clickable
in the imported commit logs, the ones done directly through github
will be ok.
thomas
> Steve
> -----Original Message-----
> From: mapserver-dev-bounces at lists.osgeo.org [mailto:mapserver-dev-bounces at lists.osgeo.org] On Behalf Of thomas bonfort
> Sent: Monday, April 02, 2012 9:28 AM
> To: MapServer Dev Mailing List
> Subject: [mapserver-dev] RFC84 call for vote: migrate from svn/trac to git/github
> http://trac.osgeo.org/mapserver/browser/trunk/docs/en/development/rfc/ms-rfc-84.txt
> I have updated the RFC with the discussion related to ticket history (which can be nearly seamlessly imported), and removed the option of continuing using the current trac instance.
> The target result can be found here: https://github.com/mapserver (still missing the msautotest and tinyows repos, and with a temporary ms-import one)
> Given that the discussion around this RFC has happened and that most of the reluctances have been sorted out, I would like to call for a vote on this. In case of success, trac and svn would need to be freezed, and we could be up and running on github by the end of the week.
> I'll start with my +1
> regards,
> thomas
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
