[mapserver-dev] Bug in trunk? layer with object getting rendered by
two classes
Stephen Woodbridge
woodbri at swoodbridge.com
Tue Apr 3 11:41:04 EDT 2012
Hi all,
I think I have found a weird bug where an objects are getting rendered
by two classes in a layer, which is counter to my understanding of how
this should work. Here is the scenario, drawing tiger roads I have a lot
of class to deal with rendering styles for various categories. I have
removed a bunch of classes that did not pertain to this issue. In the
mapfile fragment below I have marked the two classes the are getting
rendered. The second class has a restricted scale on it that is a
narrower range that the first class and they have different expressions,
but I would still expect the object to only be rendered once.
Does this look like a bug? I'll write it up if so. Does this description
provide enough detail to find the bug in the code. If not I can try to
make a simplified example.
Thanks,
-Steve W
LAYER
NAME "roads"
METADATA
"ows_title" "Roadway features"
"ows_srs" "EPSG:4269 EPSG:4326"
"ows_abstract" "Road way features from the U.S. Census
ROADS data layer."
END
TYPE LINE
TILEINDEX "tidx-ROADS"
PROJECTION
"+proj=longlat +ellps=GRS80 +datum=NAD83" #EPSG: 4269
END
INCLUDE "map-ROADS.inc"
END
# map-ROADS.inc
# S1100, 20533, primary
# S1200, 325140, secondary
# S1400, 16320345, local
# S1500, 374859, 4wd trail
# S1630, 176149, ramp
# S1640, 176415, service along highway
# S1710, 17033, walkway
# S1720, 241, stairway
# S1730, 72743, alley
# S1740, 2255679, private
# S1750, 434084, census use
# S1780, 10645, parking lot
# S1820, 2893, bike path
# S1830, 12, bridle path
MAXSCALEDENOM 500000
CLASSITEM "RTTYP"
LABELITEM "FULLNAME"
SIZEUNITS METERS
CLASS # <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<< this is drawn <<<<<<<<<
EXPRESSION /^[USC]/
STYLE
COLOR "#FFFB89"
WIDTH 18
OUTLINECOLOR "#ECD390"
OUTLINEWIDTH 4 ## make it big to verify this class is drawn ######
END
LABEL
EXPRESSION ('[RTTYP]' = 'U' && '[RTENUM]' ~ '.')
TEXT '[RTENUM]'
STYLE
SYMBOL "U"
SIZE 20
MINSIZE 20
MAXSIZE 20
END
SIZE TINY
POSITION CC
#OFFSET 1 0
MINDISTANCE 100
REPEATDISTANCE 100
COLOR "#000000"
PARTIALS FALSE
PRIORITY 6
END
LABEL
MAXSCALEDENOM 300000
EXPRESSION ('[RTTYP]' = 'S' && '[RTENUM]' ~ '.')
TEXT '[RTENUM]'
STYLE
SYMBOL "S"
SIZE 20
MINSIZE 20
MAXSIZE 20
END
SIZE TINY
POSITION CC
MINDISTANCE 100
REPEATDISTANCE 100
COLOR "#000000"
PARTIALS FALSE
PRIORITY 5
END
LABEL
MAXSCALEDENOM 200000
TYPE TRUETYPE
FONT "arial"
SIZE 16
MAXSIZE 10
MINSIZE 8
COLOR "#816C34"
OUTLINECOLOR "#FFFB89"
PARTIALS FALSE
MINDISTANCE 250
MINFEATURESIZE 10
BUFFER 4
ANGLE FOLLOW
PRIORITY 7
END
END
CLASS
MINSCALEDENOM 30000
EXPRESSION ('[MTFCC]' = 'S1400')
STYLE
COLOR "#c1c1a1"
WIDTH 6
MINWIDTH 0.5
END
END
CLASS ## <<<<<<<<<<<<<<<<<<<<<<<<<<<<<< this is draw <<<<<<<<<<<<<<<<
MAXSCALEDENOM 30000
# tried this expression also and it does not filter it out
#EXPRESSION ('[MTFCC]' = 'S1400' && ! '[RTTYP]' ~ '^[USC]')
STYLE
#COLOR "#FFFFFF"
COLOR "#FF0000" ## make it RED to verify this is also drawn #####
WIDTH 18
#MINWIDTH 10
MAXWIDTH 10
OUTLINECOLOR "#D8D4C8"
OUTLINEWIDTH 1.0
END
LABEL
MAXSCALEDENOM 20000
TYPE TRUETYPE
FONT "arial"
SIZE 18
MAXSIZE 10
MINSIZE 8
COLOR "#645C58"
OUTLINECOLOR "#FFFFFF"
PARTIALS FALSE
MINDISTANCE 250
MINFEATURESIZE 10
BUFFER 4
ANGLE FOLLOW
PRIORITY 7
END
END
