[mapserver-dev] Server-side Simplication Speed-up
Paul Ramsey
pramsey at opengeo.org
Sun Apr 8 08:03:28 EDT 2012
You are probably right. I can test this without mucking with vtables.
I think the invalid/error problem would not be a big deal, because the
idea is to drop vertices at below the pixel level. However, talking
with strk, it's possible that MapNik actually lacks a generic
decimation routine in their pipeline, so his optimization not only
reduced the amount of data crossing the pipe from the database, but
also cut down the amount hitting the renderer, which would have been
the big win. In which case for us (who already have a decimator
further up the pipeline) decimating at the datastore level would yield
much lower returns. Andrea Aime says he already tried data-store level
simplification in GeoServer and saw no speed-up (GeoServer also has a
generic decimator already).
So, anyway, I'll run the experiment at some point and report back, but
no urgency here.
P.
On Sun, Apr 8, 2012 at 3:05 AM, thomas bonfort <thomas.bonfort at gmail.com> wrote:
> I'm somewhat suspicious as to the real-world usage of such a feature:
> Quality-wise, st_simplify produces some invalid geometries that have
> to be filtered out, resulting in corrupt output when you are
> visualizing adjacent features. If you have a look at this map
> http://t.co/KVaLpOV1 (which I suppose has this feature incorporated,
> if not my reasoning is wrong) and zoom out far enough you'll see that
> all the discarded features make up for a corrupt output. Basically
> it's correct to filter out a tiny feature when it's on its own, but
> not when it is topologically linked to surrounding features.
> Performance-wise, you are getting a speedup when the scale of the data
> you are rendering is grossly out of scale compared to the scale at
> which you are rendering it. When rendering openstreetmap data, this
> happens on the first zoom levels, and so this 75% speedup concerns
> only a fraction of the renderings that occur when seeding a complete
> tileset. Openstreetmap data imported with Imposm would benefit much
> less from this feature, as it generates simplified geometries that can
> be used to avoid using out-of-scale data.
> For MapServer, we already have a simplification routine happening,
> (ticket https://github.com/mapserver/mapserver/issues/2381 discusses
> the issue, and links to the nabble discussion that happened on -dev) .
> It works at the pixel level (once the features have been transformed
> from geometry space to pixel space), and as such does not need to know
> at what scale the data is being rendered in (basically, a feature
> that's smaller than a pixel, or two successive vertices closer to each
> other than a pixel, are candidates for simplification). Supposing
> postgis's st_simplify isn't more efficient than mapserver's
> simplication algorithm (which I hope it is not, mapserver's one is
> really stupid :) ), the only gain we could hope for with this feature
> is the time taken to send the data down the wire from postgis to
> mapserver, and eventually the overhead of allocating a larger number
> of points than what will actually be rendered. Unless my reasoning is
> flawed or someone can show me the hard numbers that we have something
> to gain from this, I think that changing our input data vtables is too
> big a cost for the hypothetic speedup that would occur in only a minor
> percent of the actual renders.
> Best regards,
> thomas
> On Thu, Mar 22, 2012 at 20:59, Paul Ramsey <pramsey at opengeo.org> wrote:
>> Sandro working on MapNik says that this change
>> https://github.com/mapnik/mapnik/issues/1136
>> running an "appropriate" st_simplify on the geometries before sending
>> them over the wire to the renderer, gave up to 75% speedups on
>> rendering complicated items.
>> In order to try it out on MapServer, the PostGIS driver needs to know
>> two things:
>> - what's the resolution being rendered to? this I can pick up out of
>> the mapObj easily I think, tracing back up from the layerObj passed
>> into the driver
>> - is this a rendering call to the driver, or a feature access call?
>> this is harder... I need to distinguish between calls to the driver
>> that are going to use the features for rendering and those that are
>> going to send them back to the requester as data. Is there an obvious
>> global way to figure this out from the driver level?
>> P.
>> mapserver-dev mailing list
>> mapserver-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
