[mapserver-dev] SEGV in current trunk in labelcache code
Stephen Woodbridge
woodbri at swoodbridge.com
Wed Apr 25 00:39:17 EDT 2012
This is based on the current trunk
https://github.com/mapserver/mapserver/issues/4291
woodbri at mappy:/u/data/tiger2011-maps$ gdb /usr/local/bin/mapserv
GNU gdb 6.8-debian
Copyright (C) 2008 Free Software Foundation, Inc.
License GPLv3+: GNU GPL version 3 or later
<http://gnu.org/licenses/gpl.html>
This is free software: you are free to change and redistribute it.
There is NO WARRANTY, to the extent permitted by law. Type "show copying"
and "show warranty" for details.
This GDB was configured as "x86_64-linux-gnu"...
(gdb) run
QUERY_STRING='MAP=%2Fu%2Fdata%2Ftiger2011-maps%2Ftiger2011-tmp.map&FORMAT=image%2Fpng&MAP_IMAGETYPE=agg_qn&LAYERS=Tiger_2011&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&SRS=EPSG%3A900913&BBOX=-10719843.620153,4810106.3951652,-10505819.946325,4978267.853173&WIDTH=700&HEIGHT=550'
Starting program: /usr/local/bin/mapserv
[Thread debugging using libthread_db enabled]
warning: Lowest section in /usr/lib/libicudata.so.38 is .hash at
0000000000000120
[Wed Apr 25 00:30:51 2012].192857 msDrawMap(): rendering using
outputformat named agg_qn (AGG/PNG).
[Wed Apr 25 00:30:51 2012].193166 msDrawMap(): WMS/WFS set-up and query,
0.000s
[Wed Apr 25 00:30:51 2012].232325 msDrawMap(): Layer 2 (World Z2), 0.039s
[Wed Apr 25 00:30:51 2012].233399 msDrawMap(): Layer 3 (Forest), 0.001s
[Wed Apr 25 00:30:51 2012].233974 msDrawMap(): Layer 6 (Lakes Z2), 0.001s
[Wed Apr 25 00:30:51 2012].234541 msDrawMap(): Layer 7 (World Boundaries
Z1), 0.001s
[Wed Apr 25 00:30:51 2012].359758 msDrawMap(): Layer 17 (state), 0.125s
[Wed Apr 25 00:30:51 2012].393748 msDrawMap(): Layer 19 (place), 0.034s
[Wed Apr 25 00:30:51 2012].423610 msDrawMap(): Layer 21
(area_landmarks), 0.030s
[Wed Apr 25 00:30:51 2012].424556 msDrawMap(): Layer 22 (military), 0.001s
[Wed Apr 25 00:30:51 2012].438649 msDrawMap(): Layer 23
(area_water_far), 0.014s
[Wed Apr 25 00:30:51 2012].536266 msDrawMap(): Layer 27 (pri_sec_roads),
0.098s
[Wed Apr 25 00:30:51 2012].536364 msDrawLabelCache():
labelcache_map_edge_buffer = 10
[New Thread 0x7f2dedd4b710 (LWP 20510)]
Program received signal SIGSEGV, Segmentation fault.
[Switching to Thread 0x7f2dedd4b710 (LWP 20510)]
0x00007f2de52dfaf2 in strcmp () from /lib/libc.so.6
(gdb) bt
#0 0x00007f2de52dfaf2 in strcmp () from /lib/libc.so.6
#1 0x00007f2ded96dd0c in msTestLabelCacheCollisions (map=0x1930c50,
cachePtr=0x1add7b0, poly=0x7fff7603cd50, mindistance=100,
current_priority=6, current_label=153) at maplabel.c:804
#2 0x00007f2ded9c3413 in msDrawLabelCache (image=0x1938450, map=0x1930c50)
at mapdraw.c:3086
#3 0x00007f2ded9b6369 in msDrawMap (map=0x1930c50, querymap=0)
at mapdraw.c:494
#4 0x00007f2ded9a5516 in msWMSGetMap (map=0x1930c50, nVersion=65793,
names=0x192f940, values=0x192fc70, numentries=13,
wms_exception_format=0x1930980 "application/vnd.ogc.se_inimage",
ows_request=0x7fff7603d390) at mapwms.c:4024
#5 0x00007f2ded9aa082 in msWMSDispatch (map=0x1930c50, req=0x192f900,
ows_request=0x7fff7603d390, force_wms_mode=0) at mapwms.c:5443
#6 0x00007f2ded9e68fe in msOWSDispatch (map=0x1930c50, request=0x192f900,
ows_mode=-1) at mapows.c:275
#7 0x00007f2deda4a69a in msCGIDispatchRequest (mapserv=0x192f6c0)
at mapservutil.c:1631
#8 0x0000000000401320 in main (argc=2, argv=0x7fff7603d568) at
mapserv.c:200
(gdb) up
804 if(mindistance >0 &&
(gdb) l
799 ** value between the labels and not only from point to
point.
800 **
801 ** Note 2: We only check the first label (could be
multiples (RFC 77)) since that is *by far* the most common
802 ** use case. Could change in the future but it's not
worth the overhead at this point.
803 */
805 (cachePtr->layerindex == curCachePtr->layerindex) &&
806 (cachePtr->classindex == curCachePtr->classindex) &&
807 (strcmp(cachePtr->labels[0].annotext,
curCachePtr->labels[0].annotext) == 0) &&
808 (msDistancePointToPoint(&(cachePtr->point),
&(curCachePtr->point)) <= (mindistance + label_width))) { /* label is a
duplicate */
(gdb) p curCachePtr->labels[0].annotext
$1 = 0x0
(gdb) p cachePtr->labels[0].annotext
$2 = 0x1acb760 "159"
(gdb)
