[mapserver-dev] mapcache compile issue
Stephen Woodbridge
woodbri at swoodbridge.com
Thu Apr 26 09:33:44 EDT 2012
OK, then you need to update you INSTALL document because it claims
support for sqlite 3.5+. I'm planning on server upgrades this weekend.
-Steve
On 4/26/2012 3:23 AM, thomas bonfort wrote:
> Hi Steve,
> Lenny is now unsupported by debian themselves, and sqlite 3.5 is
> getting rather old. I'm not surprised that mapcache won't compile
> against it, and will not personally commit to making it happen,
> although will apply a pull request if submitted.
> regards,
> thomas
> On Thu, Apr 26, 2012 at 06:14, Stephen Woodbridge
> <woodbri at swoodbridge.com> wrote:
>> Hi Thomas,
>> Just tried to compile mapcache trunk from git and failed with the following:
>> /bin/sh ../libtool --tag CC --mode=compile gcc -DUSE_PCRE -DUSE_OGR
>> -DUSE_GEOS -DUSE_SQLITE -DUSE_TIFF -DUSE_BDB -DLINUX=2 -D_REENTRANT
>> -D_GNU_SOURCE -pthread -O2 -Wall -DHAVE_SYMLINK -DNDEBUG -I../include
>> -I/usr/include/apr-1.0 -I/usr/include/apr-1.0 -I/usr/include/postgresql
>> -I/usr/include/mysql -c cache_sqlite.c
>> libtool: compile: gcc -DUSE_PCRE -DUSE_OGR -DUSE_GEOS -DUSE_SQLITE
>> -DUSE_TIFF -DUSE_BDB -DLINUX=2 -D_REENTRANT -D_GNU_SOURCE -pthread -O2 -Wall
>> -DHAVE_SYMLINK -DNDEBUG -I../include -I/usr/include/apr-1.0
>> -I/usr/include/apr-1.0 -I/usr/include/postgresql -I/usr/include/mysql -c
>> cache_sqlite.c -fPIC -DPIC -o .libs/cache_sqlite.o
>> cache_sqlite.c: In function '_sqlite_reslist_get_rw_connection':
>> cache_sqlite.c:111: error: 'SQLITE_OPEN_NOMUTEX' undeclared (first use in
>> this function)
>> cache_sqlite.c:111: error: (Each undeclared identifier is reported only once
>> cache_sqlite.c:111: error: for each function it appears in.)
>> cache_sqlite.c: In function '_sqlite_reslist_get_ro_connection':
>> cache_sqlite.c:143: error: 'SQLITE_OPEN_NOMUTEX' undeclared (first use in
>> this function)
>> '_mapcache_cache_sqlite_configuration_parse_xml':
>> cache_sqlite.c:386: warning: implicit declaration of function
>> 'sqlite3_initialize'
>> cache_sqlite.c:388: warning: implicit declaration of function
>> 'sqlite3_config'
>> cache_sqlite.c:388: error: 'SQLITE_CONFIG_MULTITHREAD' undeclared (first use
>> in this function)
>> make[1]: *** [cache_sqlite.lo] Error 1
>> make[1]: Leaving directory `/u/software/mapserver-git/mapcache/lib'
>> make: *** [all] Error 2
>> Configured like this:
>> woodbri at mappy:/u/software/mapserver-git/mapcache$ ./configure
>> --enable-module
>> checking build system type... x86_64-unknown-linux-gnu
>> checking host system type... x86_64-unknown-linux-gnu
>> checking how to print strings... printf
>> checking for gcc... gcc
>> checking for C compiler default output file name... a.out
>> checking whether the C compiler works... yes
>> checking whether we are cross compiling... no
>> checking for suffix of executables...
>> checking for suffix of object files... o
>> checking whether we are using the GNU C compiler... yes
>> checking whether gcc accepts -g... yes
>> checking for gcc option to accept ISO C89... none needed
>> checking for a sed that does not truncate output... /bin/sed
>> checking for grep that handles long lines and -e... /bin/grep
>> checking for egrep... /bin/grep -E
>> checking for fgrep... /bin/grep -F
>> checking for ld used by gcc... /usr/bin/ld
>> checking if the linker (/usr/bin/ld) is GNU ld... yes
>> checking for BSD- or MS-compatible name lister (nm)... /usr/bin/nm -B
>> checking the name lister (/usr/bin/nm -B) interface... BSD nm
>> checking whether ln -s works... yes
>> checking the maximum length of command line arguments... 98304
>> checking whether the shell understands some XSI constructs... yes
>> checking whether the shell understands "+="... yes
>> checking how to convert x86_64-unknown-linux-gnu file names to
>> x86_64-unknown-linux-gnu format... func_convert_file_noop
>> checking how to convert x86_64-unknown-linux-gnu file names to toolchain
>> checking for /usr/bin/ld option to reload object files... -r
>> checking for objdump... objdump
>> checking how to recognize dependent libraries... pass_all
>> checking for dlltool... no
>> checking how to associate runtime and link libraries... printf %s\n
>> checking for ar... ar
>> checking for archiver @FILE support... @
>> checking for strip... strip
>> checking for ranlib... ranlib
>> checking for gawk... no
>> checking for mawk... mawk
>> checking command to parse /usr/bin/nm -B output from gcc object... ok
>> checking for sysroot... no
>> checking for mt... mt
>> checking if mt is a manifest tool... no
>> checking how to run the C preprocessor... gcc -E
>> checking for ANSI C header files... yes
>> checking for sys/types.h... yes
>> checking for sys/stat.h... yes
>> checking for stdlib.h... yes
>> checking for string.h... yes
>> checking for memory.h... yes
>> checking for strings.h... yes
>> checking for inttypes.h... yes
>> checking for stdint.h... yes
>> checking for unistd.h... yes
>> checking for dlfcn.h... yes
>> checking for objdir... .libs
>> checking if gcc supports -fno-rtti -fno-exceptions... no
>> checking for gcc option to produce PIC... -fPIC -DPIC
>> checking if gcc PIC flag -fPIC -DPIC works... yes
>> checking if gcc static flag -static works... yes
>> checking if gcc supports -c -o file.o... yes
>> checking if gcc supports -c -o file.o... (cached) yes
>> checking whether the gcc linker (/usr/bin/ld -m elf_x86_64) supports shared
>> libraries... yes
>> checking whether -lc should be explicitly linked in... no
>> checking dynamic linker characteristics... GNU/Linux ld.so
>> checking how to hardcode library paths into programs... immediate
>> checking whether stripping libraries is possible... yes
>> checking if libtool supports shared libraries... yes
>> checking whether to build shared libraries... yes
>> checking whether to build static libraries... no
>> checking for gcc... (cached) gcc
>> checking whether we are using the GNU C compiler... (cached) yes
>> checking whether gcc accepts -g... (cached) yes
>> checking for gcc option to accept ISO C89... (cached) none needed
>> checking for a BSD-compatible install... /usr/bin/install -c
>> checking for ANSI C header files... (cached) yes
>> checking for symlink... yes
>> checking for apxs2... /usr/bin/apxs2
>> checking for apachectl utility... /usr/sbin/apache2ctl
>> checking whether to enable FASTCGI... not requested. use --with-fastcgi=dir
>> to enable
>> checking for apr-config in default locations... using /usr/bin/apr-config,
>> use --with-apr-config=/path/to/apr-(1-)config to modify
>> checking for apu-config in default locations... using /usr/bin/apu-config,
>> use --with-apu-config=/path/to/apu-(1-)config to modify
>> checking for apr_memcache_hash in -laprutil-1... no
>> configure: WARNING: supplied apr-util does not contain memcache functions.
>> memcache cache backend disabled
>> checking sqlite3.h usability... yes
>> checking sqlite3.h presence... yes
>> checking for sqlite3.h... yes
>> checking for sqlite3_open_v2 in -lsqlite3... yes
>> using libsqlite3 from system libs.
>> checking for pkg-config... /usr/bin/pkg-config
>> checking for Pixman... searching default locations
>> checking for pixman pkg-config entry... found
>> checking if pixman version is>= 0.13.2... 0.10.0
>> configure: WARNING: pixman support has been disabled because your version is
>> too old.
>> full WMS will use the internal (usually slower) image
>> merging functions
>> configure: checking where PNG is installed...
>> checking for png_init_io in -lpng... yes
>> checking png.h usability... yes
>> checking png.h presence... yes
>> checking for png.h... yes
>> using libpng from system libs.
>> checking setjmp.h usability... yes
>> checking setjmp.h presence... yes
>> checking for setjmp.h... yes
>> configure: checking where JPEG is installed...
>> checking for jpeg_read_header in -ljpeg... yes
>> checking jpeglib.h usability... yes
>> checking jpeglib.h presence... yes
>> checking for jpeglib.h... yes
>> using libjpeg from system libs.
>> configure: checking where TIFF is installed...
>> checking for TIFFReadScanline in -ltiff... yes
>> checking tiffio.h usability... yes
>> checking tiffio.h presence... yes
>> checking for tiffio.h... yes
>> using libtiff from system libs.
>> checking for pcre library inclusion... in system locations
>> checking for pcre_compile in -lpcre... yes
>> checking pcre.h usability... yes
>> checking pcre.h presence... yes
>> checking for pcre.h... yes
>> checking for gdal-config... /usr/local/bin/gdal-config
>> checking for geos-config... /usr/bin/geos-config
>> checking for GEOSPreparedIntersects in -lgeos_c... yes
>> checking for db.h... 4.6.21
>> checking for library containing Berkeley DB 4.6.21... -ldb
>> checking in /usr/local/BerkeleyDB.4.5/include for db.h... yes
>> checking in /usr/local/BerkeleyDB.4.5/lib for library -ldb... 4.5.20
>> configure: using Berkeley DB version 4.6.21
>> checking for curl-config... /usr/bin/curl-config
>> configure: creating ./config.status
>> config.status: creating Makefile.inc
>> config.status: creating nginx/config
>> config.status: creating lib/Makefile
>> config.status: creating apache/Makefile
>> config.status: creating util/Makefile
>> config.status: creating cgi/Makefile
>> config.status: executing libtool commands
>> Have SQLite versions:
>> libsqlite3-0/lenny uptodate 3.5.9-6
>> libsqlite3-dev/lenny uptodate 3.5.9-6
>> Any ideas?
>> I can open a ticket if you want it.
>> Thanks,
>> -Steve
>> mapserver-dev mailing list
>> mapserver-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
